? Rubber or Poly. ?
Actually I got it here. Not trying to sell anything but my opinion, but thats what we do on this forum.
http://www.google.com/url?sa=t&sourc...83RxRRvnVK-5xQ
Resource
Energy Suspension, 1131 Via Callejon, San Clemente, CA 92673, 949/361-3935, 888/913-6374, www.energysuspension.com
Copyright autoMedia.com 2000-2010
Gee- what is it that Energy Suspension sells?
motor mounts,
trans mount,
rear end,
rear tie rods,
front suspension,
sway bars,
control arms,
replacing body mounts soon.
They deteriorate at a much slower rate than rubber, and are oil resistant!
But do some research of your own.
I already purchased rubber body mounts, and I think the rear diff. snubber bushing should be rubber. But It also make sense that suspension parts could benefit from quality poly bushings.Then balanced with GOOD shocks and tires.
Thanks everyone.
Poly bushing work on the parts rotating. Poly is a sticky plastic, tending to stick to the sleeves and such, producing squeeking.
The shafts and A-arms are not made to exact tolerances (ask me how i know...). To make a bushing that relies solely on rotation work, the alignment of the bushings/shafts must be nearly perfect. If not the shaft will edge ride in the bushing creating excessive wear and causing squeeks.
Rubber allows for a lot more error in the alignment and thus ease in production. Plus it is cheap to produce and doesn't require much maintenance.
From a performance point of view i always though of poly's as a bad solution to the problem. Some kind of solid would be a good solution, but means you would need to get everything aligned properly, meaning a lot of work and requiring more maintenance.
I tried getting perfectly machined shafts and such, but to expensive. Going back to rubber as soon as i get my parts and forget about it.
I went with all poly bushings to sharpen up the handling a bit. The car had the OE sized tires on it, 225/70/15, which have a LOT of sidewall height, so I found no deteroriation in ride quality, as the tires soaked it up.
Two others:
1) many bushing locations are required to flex in all three planes simultaneously as the suspension moves through it's normal arc, the best example being front trailing arm bushings. Rubber is well adapted to this, poly is not. This introduces the possibility of binding or the need to reduce the the rigidity of the poly to compensate, which doubly backfires- see point 2
2) conventional bushing design specifically introduces torsion into the bushing material to vary compressibility/compliance as the suspension moves. This is achieved by bonding the material to the inner and outer shells, then positively locating the shells into final position when assembling the car. This is why the suspension must be at normal ride height whne torquing the assembly bolts and nuts. The effect is a calculated amount of shock absorption when the suspension is in the neutral position (reducing vibration, chatter etc.) but reduced compliance on a logarithmic scale as the suspension moves towards either limit. The compliance of the twisted rubber at it's design limit is equal to or less than poly, but without the teeth rattling while at normal ride height.
Poly bushings do not operate in the same manner at all- the material does not have the ability to be put into torsion giving it the desired variable compliance and as such is not bound to the suspension or chassis. Essentially, it's at 'full hardness' all the time. Eliminating vibration isolation opportunities by using poly body mounts, motor mounts or rear crossmember/diff mounts makes little sense to me.
What's left? Front anti roll bar link end bushings. No harm there I guess other than it introduces reaction from the bar at a faster rate than stock. No idea if anyone would notice or that the accelerated transition is a good thing.
Aside from that, sure knock yourself out. Poly wanna cracker?
Are poly bushings the best at anything? Not in particular, but they happen to fall right into the big gray area between ride quality and cornering capability (as do big bar soft spring (BBSS) setups IMCO), and swimming in that bowl of soup is just where many an owner wishes to be. Yes, rubber bushings and such may be great for their intended purposes. However, it shouldn't be assumed in the discussion that we all share those same purposes.
The point is, this isn't always a black & white issue with a one-size-fits-all answer, and I'd hesitate on taking anyone's side who believes it is.
*Yes, I've seen on rare occasion where gradual loading of anti-roll bar(s) can actually be desired, but that's not a geometry issue.
If you take a good look at a set of poly's the first thing you will notice how much play the bushing has in the shell and how much play there is between the sleeve and the shaft. This is all done to negate the effect of misalignment in the arms. Poly's by nature need to be considered as a solid bushing with practically no flex in them, relying soly on rotation.
BUT you can get lucky, I talked to guys that got solids on without a problem. It's one of those instances in which a poly would probably work without any squeeks or other associated problems.
To each his own but I'm tossing them out.
OK, I've installed 5 complete sets of poly A-Arm bushings (40 bushings), and have yet to see any of them that have any excess play ANYWHERE. To my experience, the poly bushings are a tight fit in the shells, the steel bushings are a snug fit inside the poly bushings, and the steel bushings are a reasonably snug, rotating fit on the a-arm shafts or bolts.
Just my $0.02 worth.....
Maybe you had the wrong bushings? My bushings fit nice and snug, then I tapped the sleeve in with a hammer. Even used the VBP offset control arms.
If you wiggle the diverse components in their housing and on the shaft, you will notice the movement.
All the talk about rotation with poly just makes me think, what the rubber must be going through with the same rotational forces. Rubber tears and rips, poly does not but can crack. Poly glides, rubber sticks and pills.
As far as engineering from 40 years being good by today's standards (using original rubber)......well, I guess I can only hope all the new Corvette guys think the same way, as I want to trade them my high performance originally engineered iron 350 and iron heads for their aluminum LS motor and aluminum heads. New times, new materials, new ideas, better outcomes=progress.
Oh well, that's what the poly-pushers count on anyway.
