Help identifying Chevy Big Block
Old Jan 22, 2011 | 01:29 AM
dan_yoyo's Avatar
dan_yoyo
Default Help identifying Chevy Big Block
Good day everyone, just picked up this Chevy Big Block at a local Mazda shop here in Japan. This beast cost me a six pack of Budweiser and thats it.
The shop owner said it is an early model 427, but thats all he knows. Said it runs, has good compression and no know issues. The casting number looks a little odd to me, looks double stamped?
The engine is complete from air filter to 4 speed tranny. I will be taking a shot of the cylinder head numbers later this evening. Would just like to know what it is and if it's worth saving.
Can anyone help identify this enging by the casting number?
Thanks,
Dan
Old Jan 22, 2011 | 01:55 AM
razman's Avatar
razman
68' 427/390hp 4 speed???? what is the block casting number and casting date? pad stamping looks suspicious......VIN # double stamped on one digit, and date/IL is kinda slanted. dunno?
price doesn't seem bad, bud light or regular bud? Rick
Old Jan 22, 2011 | 02:03 AM
dan_yoyo's Avatar
dan_yoyo
A 6-pac of regular bud. Not sure why the Japanese men like the Bud so much, Japanese beer is so much better.
Doesn't look right to me either, has anyone else seen slanted numbers before?
Old Jan 22, 2011 | 02:25 AM
d555's Avatar
d555
Default Bbc i.d- 'il'
0424IL-April 24th 1966 427/390hp Manuel trans. First year of the 427, closed chamber heads, 2-bolt main, 2.06Int/1.72Ex. valve size. Oval port heads. Whats the head and block casting Numbers? 65 and 66 BB had the date castings half way between the front and back of the block next to the pan. The block casting # would be behind the drivers side head. The early blocks used a grooved cam and cam bearings, as oiling was a little differant than the 67 on.
Somebodys looking for that motor! ...Just not sure if that somebody's in Japan.
Post the block and head casting numbers.
Dave,
Old Jan 22, 2011 | 09:47 AM
24695bob's Avatar
24695bob
Dave,
IO code = from what I can see...
1. regular Passenger car in 1966 4 barrel / air/ turbo hydro tranny
2, regular passenger car in 1967 same combo as above
3...1967 CORVETTE 3x2 barrel / high performance turbo hydro 400 tranny,.....
Only 3 references to a IO code...
Bob G.
From the green book by W.McComas
Old Jan 22, 2011 | 10:24 AM
Mike Ward's Avatar
Mike Ward
The VIN derivative identifies it as the engine out of '68 Corvette S/N 17890 or 17899.
T0424IL = 427/390 with 4 speed built in Tonawanda on April 24th.
Nice find! Wonder if the car is still around?
Old Jan 22, 2011 | 11:37 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Yep. Pad numbers are okay for a May built '68. Block casting number will help confirm the pad stamps.
I'm guessing #17890 was the car before it; this one was to be #17891. Worker forgot to change the gang tool and stamped 17890, realized the mistake, then hand stamped the 1 -- probably while he was changing the gang tool to 17892.
Old Jan 22, 2011 | 06:25 PM
d555's Avatar
d555
Yea, Mikes right. My Suffix code source was on the weak side. Did't show that the IL code used for 66-68 yrs. Just said 66, even though the Vin plainly said it was installed in a 68
Thats a great find
DP
Old Jan 23, 2011 | 02:30 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
Slanted is ok, as long as they are all on the same baseline.......not one higher or lower then another as they were supposed to be stamped all together at once, NOT inividually.
Dates appear corect as my car is TO0401IM & my mine is almost exactly 2,000 units before yours for an april 1st build with a 4spd.
To Help identifying Chevy Big Block
