78 Pace Car Questions
1-I have found that my spare tire is dry rotted: Where can I find a replacement for the Polyspare Goodyear (P195 80/D15)?
2-I wish to change the rear limited slip differential fluid: What type of gear oil/weight and additive should be used? Does anyone know the GM part numbers of these products and quanity needed?
Thanks everyone for your help:
Bill
noticed they are looking for $250
2. Since you asked for GM:
1 bottle http://www.ecklers.com/positraction-...-additive.html
2 bottles http://www.ecklers.com/differential-gear-lubricant.html
Posted the link so you can get the gm number. I checked with a dealer and they sell the posi for $8.44 a bottle. Your call.
BTW unless you are trying to do an NCRS type restoration, be careful what you put in your spare carrier if you ever intend to use it. anything that old is certainly dry rotted and would be very unsafe.
There is no need to buy the posi addative from a Corvette vendor, and pay freight to get it. You can get it through your local Chevy dealer.
I don't know if these are the current part numbers, but I show the posi addative as 1052358 for a 4 oz. bottle (4 oz. is all you'll need), and 1052271 for a 24 oz. bottle of rear gear lube (you need 4 bottles of these). You shouldn't really need the part numbers, as every GM parts department should have it on the shelf.
I used slightly less than 2 quarts when I changed fluid on my 78 <64 oz. so make sure have at least that available.
FWIW, I also used the 85-140 purchased at the local parts store.
