am I crazy?
Old Jan 26, 2011 | 10:18 PM
mds3013's Avatar
mds3013
Originally Posted by daanbc
I JUST WENT IN THE GARAGE, I FOUND IT!!!!! iTS THERE WITH GOOD INK!!!! THANKS..... Now next week my days off I have to remove the tank. The only hard part I see is getting it out between my mufflers. My exhaust is all welded. But I believe I can do it. I can't belive it. I undid those bolts that you just mentioned, I pulled back the tin. All kinds of dirt fell out! I took a mirror and saw the paper with all ink. I am hyped up now.
Great!!! I finally got something right. When you get to it use a single edged razor blade and "remove the glue from the shield" not the sticker from the glue. Scrape the paint from the shield with the blade if you have to in order to not damage the sticker. You can repaint the shield. mike...
Old Jan 26, 2011 | 10:24 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
Thanks, here's a pic=
Old Jan 26, 2011 | 10:30 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
When you get it out, don't wipe it or brush it!
Just maybe blow any heavy dust off, by mouth, and put it in a plastic sleeve.
Old Jan 26, 2011 | 10:43 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
What do you think about having it laminated?
Old Jan 26, 2011 | 11:29 PM
corvettdreamin's Avatar
corvettdreamin
I'm excited too.. will do the same when i get mine
keep us posted
