Melted battery Terminals??
Could also be your starter shorting internally when kicked in, if the melting is only when the starter is used.
You should blow fuses and links past the solenoid with enough amperage to melt a battery terminal.
By | 2026-06-16 08:01:12
By | 2026-06-15 10:32:13
By | 2026-06-15 10:17:14
By | 2026-06-09 12:46:45
By | 2026-06-09 12:16:31
By | 2026-06-08 19:53:43
By | 2026-06-03 10:34:17
By | 2026-06-03 10:21:50
By | 2026-06-03 15:43:40
By | 2026-05-28 09:31:39
