Compression Test figures
Old Jan 28, 2011 | 05:40 AM
briaineo's Avatar
briaineo
Default Compression Test figures
Would anyone know a ball park figure for cylinder compression on a '78 305.
Going to be doing the test properly over the weekend, tested one cylinder cold and got 120
this sound relatively low?
Old Jan 28, 2011 | 06:22 AM
DKDunn04's Avatar
DKDunn04
Im no expert on these engines, but for a 305 with emission controlled heads and lower compression that sounds about right.
Old Jan 28, 2011 | 07:24 AM
RIO68's Avatar
RIO68
What's considered high or low and as compared to what?? Often thought about it--I used to be told less than 90 and no more than a variation of 20 or so between cylinders????
Old Jan 28, 2011 | 08:29 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
I agree on the variation, but I thought it should be a little higher 145-160 range . of course this depends on the mileage and condition of it all, when you did the comp. test did you have the throttle fully opened. Ron
Old Jan 28, 2011 | 01:45 PM
68-427Rich's Avatar
68-427Rich
Tie the carburetor wide open. Don't worry so much about the number. You really want to see consistent numbers on all cylinders.
Old Jan 29, 2011 | 03:56 AM
WESCH's Avatar
WESCH
Hi
The actual pressure reading does not only depend on the engine static compression ( 8:1 or 10:1 ) , but also on the cam used.
The compression check is mainly to check for pressure differences between the cylinders.
Rgds. Günther
Old Jan 29, 2011 | 10:19 AM
AOS_L79's Avatar
AOS_L79
Compare the plugs too. If a low reading cylinder has a bad color plug, there may be trouble. 120 sounds pretty low to me.
To Compression Test figures
