vacuum can purpose?
Old Jan 30, 2011 | 09:51 AM
dmg1029's Avatar
dmg1029
Default vacuum can purpose?
Can someone tell me what the vacuum can above the pass side valve cover and on the fire wall is for? I know, dumb question...
Thanks,
Old Jan 30, 2011 | 10:34 AM
rvazquez's Avatar
rvazquez
St. Jude Donor '24-'25-'26
Thanks,
No such thing as a dumb question, but in the future it would help, if you told us what year car you have. The vacumn can on the firewall is to hold vacumn that operates the pop up door that hides the windshield wipers, I believe its called a 'windshield wiper door actuator' and they were yellow zinc dichromate in finish and had either a straight or curved nipple.
Hope this helped some
Regards
Roy
Old Jan 30, 2011 | 10:40 AM
dar322's Avatar
dar322
St. Jude Donor '12-'13
Pics would be nice. Is it rectangular? If it is, my guess is some kind of shaker for the alarm.
Old Jan 30, 2011 | 10:43 AM
dmg1029's Avatar
dmg1029
Interesting. I was told the wipers work fine. How can this be? It's a possible project driver...
http://picasaweb.google.com/lh/photo...eat=directlink
Old Jan 30, 2011 | 10:47 AM
GD70's Avatar
GD70
Thank you. It's a 69. Here's a pic. I know it's rough. I was looking at it for a project. I was told the wipers work so, how is it possible with no vacuum can ??
Pic didn't work.
As Roy stated, it's not a vacuum can. The Vacuum can is next to the brake master cylinder under the fender, mounted to the inner fender wheel well.
Glenn
Edit, just saw your link.
Old Jan 30, 2011 | 10:53 AM
dmg1029's Avatar
dmg1029
Interesting. So this was a can for the alarm? something that when shook or moved, set off an alarm? Was this standard?
Old Jan 30, 2011 | 11:01 AM
John 65's Avatar
John 65
Pic not coming up at the moment, but if you have a wiper door with the shorter hood on a 68-72, the wipers may work fine, but they shouldnt come on untill they get the signal from the door being in the open position.
Old Jan 30, 2011 | 11:31 AM
Alan 71's Avatar
Alan 71
Hi d,
The wiper door actuator is missing in your picture so the wiper door can't open or close unless the system has been modified. The car still has the wiper grill and door.
I don't see the can you're asking about in the picture.
Regards,
Alan
Here's a picture of the actuator for a 71. I believe the 69 had one shaped like a coffee can or this one which is shaped like two pie pans.
Old Jan 30, 2011 | 11:40 AM
Hammerhead Fred's Avatar
Hammerhead Fred
Originally Posted by Alan 71
Hi d,
The wiper door actuator is missing in your picture. The door can't open and close with out it; unless the system has been modified.
Regards,
Alan
Not to mention that there's not even a wiper motor in the photo.
Old Jan 30, 2011 | 11:48 AM
Alan 71's Avatar
Alan 71
Hi Fred,
You're right!!!
This photo must have been taken while the car was being reassembled.
Regards,
Alan
Old Jan 30, 2011 | 11:59 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...Can someone tell me what the vacuum can above the pass side valve cover and on the fire wall is for?...
For opening the wiper door. Yours is missing in the pic, along with the wiper motor.
FWIW: 69s used two different actuators; early cars used the cylindrical coffee can type like the 68s; later cars used the double pie pan type as seen in Alan's pic. Based on the bracket on the cowl, it looks like your '69 had the coffee can type.
Old Jan 30, 2011 | 12:32 PM
dmg1029's Avatar
dmg1029
Thanks. So if the wipers are working then someone modified the wiper door I think ?
Old Jan 30, 2011 | 01:08 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
And probably installed a wiper motor!
Old Jan 30, 2011 | 01:38 PM
Easy Mike's Avatar
Easy Mike
...So if the wipers are working then someone modified the wiper door I think?...
If this is your car, there is no wiper motor installed. It mounts on the firewall behind the distributor where you see the empty round opening.
I don't see how your wipers could work without a wiper motor.
Old Jan 30, 2011 | 06:27 PM
GD70's Avatar
GD70
Here's a 69 BB. You can see the gold colored "coffee can" style actuator and the wiper motor behind the distributor shielding.
Glenn
Old Jan 30, 2011 | 07:05 PM
Alan 71's Avatar
Alan 71
Hi Glenn,
It does my heart good to see that you're still here!!!!!
Regards,
Alan
Old Jan 30, 2011 | 07:13 PM
Ret.Horsecop13's Avatar
Ret.Horsecop13
St. Jude Donor '11-'12-'13-'14
Hi d,
Regards,
Alan
Alan please clean up your engine bay, its really going downhill!!
To vacuum can purpose?
Ret.Horsecop13
Hi Glenn,
Regards,
Alan
Old Jan 31, 2011 | 09:46 AM
GD70's Avatar
GD70
Hi Glenn,
Regards,
Alan
Hi Alan,
Thanks! It's in the blood you know!
The 70 is in the shop having the rear trailing arms, bearings etc... and diff rebuilt. Then new front springs, than a vintage AC system installed. The buyer lives in Atlanta. I should have some new update pics to post soon.
I'll miss it when it's gone, but I'll still be around here.
Glenn
Old Jan 31, 2011 | 11:25 AM
PRNDL's Avatar
PRNDL
and we can tell from the fuel filter it is either a 68 or 69.
