Do u start in winter?
Old Jan 31, 2011 | 07:34 PM
nutsy's Avatar
nutsy
Default Do u start in winter?
got into a conversation with some friends about if you should start your car once in a while through the winter months. i personally do not. friend says if you dont things can stick or seaze up. any truth to this? i would have a poll but i dont know how, Nutsy.
Old Jan 31, 2011 | 07:50 PM
dannyman's Avatar
dannyman
It really depends upon the storage temperature. If cold enough, starting periodically will do more harm than good if not allowed to come up to operating temps.
mds3013's Avatar
mds3013
Some of the guys were discussing this a few weeks ago. Their advice was that if you are not going to drive it, so that all parts are brought up to operating temp., you should just leave it alone. I started mine up this weekend and was amazed at how much moisture came from the exhaust. Since I drove it about 30mi. it dried up the moisture rather than it sitting in the exhaust and rusting inside. mike...
Old Jan 31, 2011 | 07:55 PM
redwingvette's Avatar
redwingvette
I have always used fogging oil when I put the Vette away for the winter. I first started using it in my boats a long time ago and just figured it would be a good thing to do with the Vette.
Old Jan 31, 2011 | 08:00 PM
U17's Avatar
U17
My training / experience on air cooled motors... If you are going to start them, run them enough to heat up and take the moisture out of the oil ect. Which means up to normal operating temps and pressures... Not just idle ... Idle will leave the conditions right for setting up a ideal scenario for "little clouds" in the engine and the begining of rust / corrosion ....
Old Jan 31, 2011 | 08:01 PM
spedaleden's Avatar
spedaleden
No start during winter, wait till spring, squirt oil into each cylinder, get oil press up and let her rip. Then change plugs once warmed up.
Old Jan 31, 2011 | 08:14 PM
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
I only start it to drive it. Last winter, there was one freaky warm day (like 50 for a high temp) in December when I was on staycation, and another on a January weekend. It hadn't snowed yet, so there wasn't any salt on the road. I started the car and took it out for a 20-30 mile ride each time, mostly just because I missed driving it.
The last time my engine ran was 11/28/10, so it has already been more than 2 months since it turned over. I don't think this is a big deal, and won't start it anytime soon given the weather. Eventually, I will need to turn it around in the garage, and I will start it for that even if I can't drive on the street, but I'll let it get fully warm before shutting it down for the above reasons. That's kind of how I play it, start for a reason = yes, start it just to start it = no.
Old Feb 1, 2011 | 08:06 AM
bashcraft's Avatar
bashcraft
Don't listen to anything this guy says. He has no idea what he's talking about. I'd just stay away from him, unless he's a relative, then you don't have a choice.
I leave a trickle charger on my battery all winter, but never start it unless I'm going to drive it. Most of the wear in an engine happens on cold starts.
Old Feb 1, 2011 | 08:36 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I only start the cars when I am able to take them for a good drive. Most winters I am able to do that. This year, forget it. It snows every day.
Old Feb 1, 2011 | 08:42 AM
1980 blue L48's Avatar
1980 blue L48
every month or two, I go out and start it, let it run on fast idle (1600 rpm) for a half hour or so. I prefer the oil be up in the top end, and in the cylinders. I don`t know if this is a good thing, or not ? Cold garage, no heat, only indoors, never seen rain.
Old Feb 1, 2011 | 08:57 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
Nope just set the charger on it and don't touch it till I'm ready to pull it out for summer. Ron
Old Feb 1, 2011 | 05:14 PM
john 72-04's Avatar
john 72-04
Start it up , bring it up to temperature , let it run another 5 to 10 minutes at two grand , shut it down and this will never hurt a thing. If weather permits always best to drive it 5 to 10 miles.
Old Feb 2, 2011 | 07:04 AM
bashcraft's Avatar
bashcraft
But what's the purpose for doing this at all?
Old Feb 2, 2011 | 07:13 AM
DO2G's Avatar
DO2G
Old Feb 2, 2011 | 07:22 AM
mikep3's Avatar
mikep3
Default No
No. Mid November to mid April, disconnect battery and it starts after I see oil pressure for the last 5 years.
Old Feb 2, 2011 | 10:13 AM
79 vette head's Avatar
79 vette head
St. Jude Donor '10
i had to start it a couple of weeks ago to move some furniture out of the house and back through the garage. the vette actually touched snow. i've been meaning to post pics of this.....i always try to start it and take it for a drive 7-10 miles. like what other people have said bring it up to temp and drive it through all the gears. this winter is not co-operating
Old Feb 2, 2011 | 10:38 AM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
If I started it I'm not going anywhere today! The vette's behind that garage door.
To Do u start in winter?
Old Feb 2, 2011 | 04:24 PM
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
One reason 'FOR ALL OF THIS " is that water vapor is a by-product of combustion and this will introduce water into your exhaust system and crankcase if you don't do all of this. The car needs to be brought up to and sustain normal operating temperature in order to burn this off. Taking the car for a drive thru all of the gears is also good for all of the
seals and the brakes if your car is the original non o-ring type. Some people prefer not to start the car at all if it cannot be driven for at least 20 minutes.
I recently fried my Harley when a battery charger went bad AND I am now so shell shocked that I prefer to start my
HARLEY, Mustang, and Vette to charge them normally. I realize this is rare but I'm sure its happened to others. Some storage facilities have rules about leaving electrical devices plugged in which takes trickle chargers out of the equation.
Old Feb 2, 2011 | 06:02 PM
leadfoot4's Avatar
leadfoot4
To circulate oil to the seals and gaskets, to keep them from drying up, preventing half of the valve springs from being under tension for extended periods, and getting the A/C circulating for the same reasons....and that's why I do it, and have been doing it since I started storing specialty cars in 1977....
Old Feb 2, 2011 | 06:06 PM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
This all seams to be advice for a cold storage. If the vette is in a heated garage, or a temperature controlled storage, does the turning it on and driving it around once every few weeks still need to be done?
How often should you run the car up to temperature?
