I need interior halp!!! 1978 vette
Old Jan 31, 2011 | 08:20 PM
UCVette's Avatar
UCVette
Default I need interior halp!!! 1978 vette
Hello all. I have a 1978 corvette, and I want to paint the top dash piece as well as the top strip in the back (both black). I need info how to remove and suggestions on how to paint. Please halp
Old Jan 31, 2011 | 08:52 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
just a suggestion, but you should get a hold of a 1978 AIM (assembly instruction manual) and it will show you how everything was assembled. it seems to me that i remember having to remove the pad front before being able to get to the dash top (but it was a long while ago). as for painting, there are many good interior paint products on the market. i suggest you try doing a search here on "interior paint" it should provide you with all the information you could want on the subject.
Old Jan 31, 2011 | 10:24 PM
Clubby99's Avatar
Clubby99
The dash must be bent to be removed. That makes it very easy to crack. Guess how I know? If I were doing it again, I'd remove all screws and loosen the dash but not remove it. Mask the interior, clean & prep the dash, and then spray the dye while the dash is in the car. By the way, my new dash cost less than $300 (Ecklers 20% off sale). Well worth the money. Kind of glad I cracked the dash.
Old Jan 31, 2011 | 10:44 PM
donnie1956's Avatar
donnie1956
Heat the dash up with a hair dryer and try to flex it to remove.
To I need interior halp!!! 1978 vette
