Rag-Joint: Rebuild, Replace or U-Joint
Old Feb 1, 2011 | 07:43 AM
MrJlr's Avatar
MrJlr
Default Rag-Joint: Rebuild, Replace or U-Joint
My rag-joint is pretty well shot....but I'm stuck in my decission...
A) There is a rebuild kit for $15...doesnt look hard - is it ?
B) Could buy a new one for $45
C) Or could get the Flaming-River U-Joint $80
What do you guys think ?
Old Feb 1, 2011 | 08:25 AM
corvetteload's Avatar
corvetteload
I would replace with another, either decision means you have to remove it to do any work, so just replace...............
Old Feb 1, 2011 | 09:37 AM
chucks's Avatar
chucks
C3 of Year Finalist (stock) 2019
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Oldtimer
Old Feb 1, 2011 | 10:36 AM
BKarol's Avatar
BKarol
If you have read any of Jim Shea's post you will know to go to GM Parts direct and order the gm part for $67 plus shipping or whatever vendor sells gm parts or go to a local dealer and pay whatever they say for the GM steering coupler. Don't skimp on something very important
IMO
Old Feb 1, 2011 | 10:50 AM
MrJlr's Avatar
MrJlr
Yup....I should have done a search.....found TONS of info on it....I'll be buying the GM Parts Direct new rag joint....
Oh - and thanks fur not razing me for not searching first ! LOL !
Old Feb 1, 2011 | 10:53 AM
Mashman's Avatar
Mashman
with all the rest.
Jim Shea says that there is a problem with all the rebuild kits that the vendors sell - none of them use shoulder bolts. You should buy a new correct rag joint from GMDirect.
Old Feb 1, 2011 | 10:59 AM
7T1vette's Avatar
7T1vette
Keep your original parts. There is probably nothing wrong with the metal components and you may need them if the "genuine GM" parts [from China but in a GM box] don't appear to be the same.
Old Feb 1, 2011 | 11:05 AM
MrJlr's Avatar
MrJlr
Just ordered a new coupling from GM Parts Direct...
Old Feb 1, 2011 | 11:16 AM
BKarol's Avatar
BKarol
I got mine from a Chevy dealer in Az . You do not get the nuts and bolts with the package so save everything. The part I got appeared to be exactly the same that I took off. Hopefully that is what you get from this vendor.
To Rag-Joint: Rebuild, Replace or U-Joint
