1972 454 auto
Old Feb 1, 2011 | 11:56 AM
maryanne's Avatar
maryanne
5th Gear
Default 1972 454 auto
"Does anyone have any recomendations on some parts that I need for my car.
I dont plan on racing the car, keeping it stock, but woulnt mind better performance.
1) water pumps,
there are so many brands, rebuilts, oem does anyone have a rec on a water pump i have looked at emp stweart ,elgin ...
2) I have to pull out my radiator, it leaks, do I have it poressured tested and fixed if its under $200.00 and if its more should i purchase another copper brass or go aluminium
3) what corvette sites are the best for getting other items, windshield wiper motor, master cyclinder
thanks in advance"
Old Feb 1, 2011 | 02:23 PM
mudbone64's Avatar
mudbone64
From: I'd like to propose a toast... to internal combustion and wind in the face.
Is your water pump original to your car? If so then have it rebuilt. If the pump is not original I would just get an original style pump a local parts store. Unless your producing some major horsepower and heat I don't see the need for anything fancy. With the exception of a hydraulic roller camshaft my '72 454 is all stock and the original pump cools the engine just fine.
I had my original radiator "re-cored" several years ago with an aluminum core. So far so good and I do believe the cost was less than $200. Having your radiator re-cored may depend on how good the radiator services are in your area. The local guy around here is quite good so I let him re-core it. The cost of a replacement radiator may be dictated by how much money you'd like to spend. Those things are pricey!
I would get my master cylinder locally if I were you. As for the windshield wiper motor, I'm afraid I don't have a recommendation because I've never had to fool with mine. I'd try the local parts stores first. If I didn't have any luck there, then I'd try one of the contributing sponsors that advertise here. I get 99% of all my parts from Volunteer Vette Products.
Good luck.
Old Feb 1, 2011 | 02:46 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by maryanne
...water pumps, there are so many brands, rebuilts, oem does anyone have a rec on a water pump i have looked at emp stweart ,elgin...
You can use your local, generic auto parts places, or any of the Corvette aftermarket providers.
...I have to pull out my radiator, it leaks, do I have it poressured tested and fixed if its under $200.00...
Have your original radiator recored.
...should i purchase another copper brass or go aluminium...
Copper and brass was stock. Aluminum would be up to you.
...what corvette sites are the best for getting other items, windshield wiper motor, master cyclinder...
Compare prices at all of them, then take your pick. You may want to consider a provider close to where you live; makes shipping a little cheaper.
Old Feb 1, 2011 | 05:59 PM
Alan 71's Avatar
Alan 71
Hi ma,
Some of the vendors that consistently get good reviews from customers in posts here are:
Zip Products
Paragon Corvette Reproductions
Corvette Central
Willcox
Give them a try!
Regards,
Alan
Old Feb 1, 2011 | 09:06 PM
maryanne's Avatar
maryanne
5th Gear
Default Thanks for the info
I just purchased the car, I have not taken out the water pump yet. I am not sure if it is original or not.I guess I will google to find out how I can tell.
I saw some oriiginal style pumps,some from NAPA that say they are reconditioned,Water Pump - Remfd
Product Line: Remanufactured Water Pump
Comments: w/ 5/8" Shaft;w/ Casting # 3992077;w/ Standard Pump;Cast Iron Housing
Per Car Qty.: 1 and one from Ecklers say new 20.00 more, manufacuted by Ac/Delco
[I]Corvette Water Pump, With 3/4" Shaft, Big Block, ACDelco, 1971-1974
Stock Replacement
This stock replacement water pump is manufactured by GM or by one of its authorized suppliers for use as a factory replacement part. You will find the fit, finish and function meets all GM specifications.
Thank you for the tip on the radiator, I have a local radiator repair shop, I have not taken it to him yet, but I belive he said it would be 3-4 to get it recored.
I could get a new one from corvette specialties for 379.00 Problem is I dont know who makes it and if it came from china!!!
Thanks again for your help I found the master cyclinder for 50% less on NAPA
Good luck.
Old Feb 1, 2011 | 09:27 PM
maryanne's Avatar
maryanne
5th Gear
Thank you
Old Feb 1, 2011 | 09:28 PM
maryanne's Avatar
maryanne
5th Gear
thank you
To 1972 454 auto
