body dolly size
Old Feb 2, 2011 | 12:48 AM
merc49's Avatar
merc49
Default body dolly size
does anyone have plans or dimensions to make a body dolly.i need to lift body off my 75 chassis and have to do it in one day so i need to premake the dolly out of wood or steel,wont have enough time to go back and forth to stores plus build the thing and lift body off.also im using an engine hoist to lift the body by myself and need to know where to safely put lifting straps on car.your help is greatly appreciated.
Old Feb 2, 2011 | 09:13 AM
thread baron's Avatar
thread baron
I don't have the links but they are easily found with a quick search. Look through the archives and you will find plenty of pics along with instructions for the Roland Dolly as well as other variations.
Old Feb 2, 2011 | 06:31 PM
Alan 71's Avatar
Alan 71
Hi m49,
I'm not sure if I understand the one day issue.
Here's the plan for the dolly I built and used.
Regards,
Alan
Old Feb 2, 2011 | 07:22 PM
Denpo's Avatar
Denpo
Originally Posted by Alan 71
Hi m49,
Regards,
Alan
Did something similar.
http://forums.corvetteforum.com/1576140129-post47.html
One important thing it to make sure the front is well supported. If left hanging in the air is can flex badly. The rear body can support itself without problem.
Old Feb 3, 2011 | 05:35 PM
Alan 71's Avatar
Alan 71
Hi,
D is right about supporting the front of the front clip.
On ths dolly the front crossmember is located so 2 supports can be installed once the body is on the dolly.
If you look carefully you can see a couple of inches of each of them in this picture. They're about 2 feet in from each side.
Regards,
Alan
Old Feb 3, 2011 | 06:55 PM
Duke94's Avatar
Duke94
I think I recall seeing a plan for a C3 body dolly in the latest NCRS Driveline but I already gave away the Mag. Anyone else still have theirs?
Gary
To body dolly size
