Fuel leak help...
Old Feb 5, 2011 | 03:44 AM
smitsc05's Avatar
smitsc05
Default Fuel leak help...
So I found fuel leaking this morning when I came out to the car. Passenger side dripping right onto the pass side muffler. Looked like a full gallon or two maybe leaked out overnight. I had just filled the tank before I garaged it.
Any ideas?
1977 L48, all original.
Old Feb 5, 2011 | 10:26 AM
PRNDL's Avatar
PRNDL
Any ideas?
Holy Crap! Any open flames nearby? (Our gas fired water heater is in the garage). I would syphon remaining gas out of tank ASAP and find the leak. Over the muffler it could be the tank, but a leak that big I would just guess it is a hose - maybe as simple as a rubber hose pulled off or a split. You just have to go up underneath and find it... of course syphoning gas first will make it harder to find source of leak, so maybe rethink that first piece of advice. I have only had to deal with a very tiny drip from a pinhole. A gusher is a lot more worrisome.
Old Feb 5, 2011 | 10:27 AM
1977L82's Avatar
1977L82
My 77 did the same thing leaked fuel by muffler I had a slice in the return line its hard to get to but I put a new hose about inches use the hose clamps that have thumb tighner ****
Old Feb 6, 2011 | 02:27 AM
smitsc05's Avatar
smitsc05
Thanks Brothas, yeah, I am hoping it's a line. The leak stopped on it's own, maybe I overfilled it? I topped off at the pump? I say about 1 gallon total leaked out.
PRNDL, no open flame anywhere near, I'm just glad I saw it before I started the car, I had my 3 yo daughter with me. Phew. Thank God I saw the gas on the garage floor. I almost always do a walk around to look for tires/ leaks/ new dings, etc. My wife always rolls her eyes at me, but this incident reminds me why I do it.
Old Feb 6, 2011 | 06:05 AM
noonie's Avatar
noonie
Leak can be anywhere. tank, hoses or steel line.
This was under the clamp on the return line.
Here is a leak on the return line. You can see the smoke from the gas hitting the hot muffler.
Pinhole in the return line under the clamp to the frame
[IMG]http://i74.photobucket.com/albums/i242/010752/Corvette/Fuel%20System/Drip2.jpg[/IMG
Old Feb 6, 2011 | 10:10 AM
GD70's Avatar
GD70
When I took the 70 for the first test drive, there was smoke coming off the right muffler. WTF! I looked under there and the rubber hose had cracked. The previous owner was a mechanic so it was fixed. After it was delivered I drove it and noticed a strong gas smell in the garage and there was a gas stain on the floor. Ended up there was a hairline crack on the sender where the nipple was welded to the plate. Replaced it and no problem since.
Glenn
Old Feb 7, 2011 | 05:21 PM
Arcticshark's Avatar
Arcticshark
I had the same problem a few years ago. Turned out to be the S lines from the fuel pump to the carb at the front of the engine! I'm not sure how fuel was travelling all the way back to the rear of the car, but it was. Mine was dripping in the same spot, passenger side rear. I thought it was a leaky tank at first too. Go figure.
Old Feb 7, 2011 | 06:46 PM
smitsc05's Avatar
smitsc05
YEP! That is exactly what it looks like (I can't believe you have a pic of it!).
Old Feb 7, 2011 | 06:50 PM
smitsc05's Avatar
smitsc05
What I don't fully understand is why it stopped leaking after about a gallon of gas dripped on to the garage floor. Maybe the pressure reduced when enough gas leaked out? Now that it's stopped, I'm temped to drive to the mechanic instead of getting it towed... but not worth the risk.
Old Feb 7, 2011 | 07:07 PM
81pilot's Avatar
81pilot
A gallon of gas would spread and cover a huge area. It does not take much to look like a lot. Where do you live? Is it hot? It could have just overpressured and forced it out, but it should not force it out right where you said since it is a closed system. I put a vented cap on mine a while back since I was not sure if my canister was hooked up right. I suppose if it built up pressure some gas would go somewhere. But check the lines closely. I am going to replace mine before spring. All the fronts are getting replaced now.
Old Feb 8, 2011 | 01:41 PM
smitsc05's Avatar
smitsc05
Good point, yes, maybe it was not a complete gallon. It's warm here and it was a hot day on the day it leaked. But it's cooler now (in the 60's).
Well, I'll be taking it in today and I'll update on what my corvette "guy" says. I'd do it myself, but with my 3 year-old daughter in the car everyday, I want a fuel leak checked right.
To Fuel leak help...
