Razor blading off old paint
Feb 7, 2011 | 11:07 AM
Hey buddies,
Moving along so I get this project done this year
, getting off the last bits and pieces of the old lacquer paint that I put on in the late 70's..
Here's the paint scraped off the hood
[/URL]
The hood now left with just the old primer
The door took a total of 1 hour and 15 minutes to do
[/URL]
Now on to doing the hardtop
Feb 7, 2011 | 11:29 AM
Thats really loking pretty good. Only 1 layer of paint to remove, thats great ! The layers never ended on my 68. You will be done before ya know it.
Feb 7, 2011 | 11:35 AM
Hi John,
Back in '76 when I did the 1st paint job on it (this will be the 2nd), I stripped it down to bare fiberglass. One thing good about the old lacquer paint is how easily it flakes off with a razor blade. Doubt I could do the same with the current 2 pack paints.
Feb 7, 2011 | 01:37 PM
Cruise-In II Veteran
The old paint on my '68 came off in long ribbons. I got into a head thing trying to see how long of a ribbon I could create. 33" was the best I could do and figured I got lucky on that one.
Feb 7, 2011 | 01:38 PM
That brings back memories, when I stripped my 73 with the razor blade tecnique. Went thru alot of blades, and a few bandaids too.
Feb 7, 2011 | 03:38 PM
Hi,
I believe that 'someone' has developed a process in which you can 're-flow' the old lacquer and spray it back on the car.
Regards,
Alan
Feb 7, 2011 | 03:47 PM
Quote:
Originally Posted by
Alan 71
Hi,
Regards,
Alan
I heard you can sweep it up off of the floor and put it in a blender with some lacquer thinner. From there straight to the spray gun.
Feb 7, 2011 | 04:37 PM
St. Jude Donor '09
bashcraft
The ultimate recycle ....
Feb 7, 2011 | 05:09 PM
Put a picture on showing what kind of scraper you used, please.
Feb 7, 2011 | 07:43 PM
is the front end off your car, i see the left front fender is partially off, what year is your car, dont want to be trouble, but i would like to see the the firewall and fender plenum areas if exposed, or if anyone else has picks of these areas i would like to compare to my 73, i think some stuff is missing after a previous crappy repair
Feb 8, 2011 | 10:59 AM
manofsteel1
Just a regular ol Single edge razor blade - see the 4th photo with the blade on the cardboard.
There is a slight technique. Start with the blade at 90 degrees and "pull" a section toward you so a line of paint is removed. Then with the blade at a more extreme angle, keep the tip along the line of removed paint. You should then be able to "flick off" about a foot at a time.
Feb 8, 2011 | 11:06 AM
Alan 71
Hi,
Regards,
Alan
lol - I was gunna say in the next to last picture that all I probably need to do is top coat over the old primer
Feb 8, 2011 | 12:36 PM
never heard of this before, but why not just sand it?
Feb 8, 2011 | 03:42 PM
RiseAbove
better to razor or liquid strip it..... i used citrus stripper on my 77
Feb 8, 2011 | 06:49 PM
RiseAbove
You cannot paint over lacquer paint with a newer paint. You must remove the lacquer paint or any new paint you put on will not stick well.
Feb 8, 2011 | 08:05 PM
Looking good, nice to see you're back at work. Get that nose glued on yet?
Jim
Feb 9, 2011 | 10:23 AM
70BBvert
Jim
Nope, not yet. The new front surround is still in the box along with the new front fenders and inner wheel wells that I bought 2 years ago
Feb 9, 2011 | 10:35 AM
TWINRAY
That's actually not that bad, it was 4 years before I finally hung the nose I bought
Jim
Feb 9, 2011 | 10:44 AM
70BBvert
Jim
then I'm actually ahead of schedule
Feb 9, 2011 | 11:24 AM
St. Jude Donor '08
I am slowly scraping my black laquer off, a little bit at a time between beers. Biggest pain is cleaning all the crap up off the shop floor, those long ribbons keep clogging up the shop vac! I plan on using epoxy primer to seal the body back after I redo all the fender seams, they are starting to separate as well.
