No Oil Pressure
I've got zero oil pressure, changed the sender and still reading zero ohm's.
Whats the next thing that I should do?
The car hasnt been driven for the past few years.
Thinking to replace the oil pump, anything else I should do before this?
Is there any difference in the way you test the ohm output on the temp sender than the oil sender?
Thought by changing over to the electric gauge you remove the risk of an oil leak inside the car!
That being said, if it were me, I want to be sure I did have oil pressure. To do this, try a mechanical gauge with a short piece of trubing. The new ones even have a plastic tubing.
Make sense?
If you got an ohm read, how would you know what that reading related to, as psi.
1) engine has no oil pressure (unlikely if it is running OK and not noisy...but be careful, just in case);
2) bad sending unit (since you've changed it, that is not likely to be the problem);
3a) bad gauge....If you can access the back of the gauge (if not in the stock gauge cluster), it should have 12v going to it and a 'signal' wire from the sender. With the ignition on, use a voltmeter to see if 12v is present at one of the connections on the back of the gauge. If not, your gauge is not getting power to it and it won't function. Find/fix the reason for not getting power to the gauge.
3b) To check the function of the gauge, disconnect the sender wire from the gauge; with voltage going to the gauge and no sender wire connected, the gauge should read "O" psi (full scale to the left). Now, connect a 'dummy' wire to that sender contact and run that wire to a known-good ground point. The gauge should read full scale to the right. If those two checks are OK, the gauge is OK.
4) bad wiring...If check #3b went as expected, then your sender wire has a break in it somewhere. Check it and/or replace it.
Good luck.
I use a oil pressure switch for my electric choke. The only way a current will head there is if I have oil pressure, meaning the car is running. In this way I can work in the engine compartment, with the key on, and not have a current on the choke.
You'd need:
* instructions for distr remove/replace
* spare distr drive shaft or purpose built oil-pump tool
* electric drill
* replacement valve cover gasket(s), distr gasket
It would involve removing the dist and a single valve cover.
Using the electric drill with attached oil-pump tool, insert shaft into distr bore, engage top of oil pump driveshaft, spin the shaft and note oil delivery from pushrod end at contact with valve's rocker arm.
You should feel the drill lug down as pressure builds. Depending on size and torque rating of drill, be careful not to burn up drill.
That'll determine whether oil pump is failed or ok. Then follow other recommendations here for the gauges, lines, etc.
