lame 85mph speedo 1981
Received 1,470 Likes
Cruise-In II Veteran
You need an aftermarket speedo like this one from Corvette Clinic. Have one in my '78, but don't know if their still available. IMHO the graphics on the ones I've seen of late aren't quite as good, so I'd be picky if there's any choice left among them.
Location: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
Received 1,457 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Does the speedo gear in the trans need to be changed as well?
Call John, he can reface and calibrate your speedo. Did mine and did a great job...
http://www.redlineg.com/redlineg/Welcome.html
my 76 ray, speak for yourself.
Guess that depends on what you call high MPH. He put mine to 140 MPH. He used to do the 165 but said those are very cluttered with the numbers so close, and there was a calibration issue too. Since my car is a street car, I thought if I'm spending any time around 140, I'm probably in trouble anyway, and knowing about the additoinal 25MPH the 165 would show, isn't gonna help!!!
I need to get this done also and have seen other people also mention
http://www.harrisonspeedometer.com/
Has anyone had experience with either one of these companies and is it $200 just for the speedometer refacing/recalibration?
And i do have a 140 MPH speedo from a 78 vette re calibrated and with the Speed sensor
so this thing won't be quite as fast as my C6 i am guessing but it's ok i can't leave stock alone so i might have to work on that a little bit
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,350 Likes
The easiest and cheapest way is to go to a swap meet and pick up a 78-79 speedo. I believe the 85 MPH ones were phased in for the 1980 and later models during the 1979 calendar production run.
I had a 1980 way back when and felt the same way- even though its illegal to go 85+, it looked bad. I was at Bloomington and easily found a '78--79 speedo and swapped it out for very little cost.
