led tail lights
Old Feb 17, 2011 | 09:09 PM
Warbonnet's Avatar
Warbonnet
Default led tail lights
Has anyone had any luck with the LED tail light conversions?, I bought a set from a major Corvette parts supply, however they will not plug into the female recepticle, these are not just the bulbs , but the whole conversion . The male end has a plastic portion that will not let the pins go in deep enough to spin and lock. I have two c-3 cars and will not fit either car, the company told me how many they had sold last year, but do I have the only two in the nation that these lights will not work in??
Old Feb 18, 2011 | 03:07 PM
Warbonnet's Avatar
Warbonnet
Problem solved, another bad batch, seems this happened about 18 months ago, , got resolved and now is happening again. Is an easy fix however
Old Feb 18, 2011 | 05:51 PM
LancePearson's Avatar
LancePearson
Question: If you do Led tailights I understand you have to change the flasher. What about the front turn signals? Do you have to convert them to LED's too to use the same flasher. I like the LED lights in the rear but am not sure about the flasher as noted above.
Old Feb 18, 2011 | 07:51 PM
Warbonnet's Avatar
Warbonnet
I am not sure about the front, I have used the flasher for the rear and not changed the fronts to LED and everything is working, You may need to check with one of the techs from the people who sell these to get your best answer.
Old Feb 19, 2011 | 12:03 AM
Ray Y's Avatar
Ray Y
You do not have to use LEDs front & rear. I'm running rear only too. The cheapest flasher replacement that I know of and it works fine, is the NAPA HD flasher. It's basically a trailer kit flasher that forces it to flash with the reduced load of the LEDs compared to the filament bulbs. I have one of the "expensive" led flashers laying in a drawer from one of the sponsors here on the forum it does not work for the LED rear only set up and the cheap NAPA flasher works fine.
Old Feb 19, 2011 | 08:00 AM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Same thing happened to me; I bought the "special" LED flasher, and it did not work! I used the NAPA HD flasher, and it worked fine.
Old Feb 19, 2011 | 08:21 AM
LancePearson
thanks...will order the led rears and get a napa hd flasher
Old Feb 19, 2011 | 11:10 AM
zapper295's Avatar
zapper295
Do you have the part# of the NAPA flasher? Thanks
Old Feb 19, 2011 | 11:17 AM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
Id like to see what people are using and maybe where they purchased them.. i have a 77 and they have a set for the 68-73 but nothing but the bubble lens for the 77. i really want the stock lens with the leds ... anyone.. ? ? ?
car is getting painted and would love to have new lens for it.
To led tail lights
