Brake light switch
Old Feb 19, 2011 | 10:25 PM
68vetteman's Avatar
68vetteman
Default Brake light switch
I bought a new brake light switch 3 years ago and it is shot already. I took it apart and the contact areas look burnt. I seem to have a lot of problems with this switch. I saw in a catalog that there is a brake switch capacitor. Does anybody know where it should be. I don't think I have one. Would this cause the switch to burn out? Thanks
68 Vetteman
Old Feb 19, 2011 | 11:13 PM
7T1vette's Avatar
7T1vette
The capacitor on the brake switch was not there to help the switch survive. It was there to 'absorb' the electical spike generated when the switch is activated or de-activated. That spike would make a noise in the radio system if it was not suppressed. The capacitor is a "radio noise suppressor".
The brake switch had burnt contacts because the aftermarket switch is "junk"...compared to the original one. GM originally sized such components to handle much more current than it would really see. Now, the aftermarket folks make only was is "required".
See if you can round up a NOS switch or find a suitable replacement from an electrical switch catalog.
Old Feb 20, 2011 | 09:21 AM
68vetteman's Avatar
68vetteman
Thanks for that information, I never heard of a "brake switch capacitor" before. I agree after disassembling the aftermarket switch that it is junk. The brass blade that makes the electrical contact is very thin. I'm going to try something and use the brass material that is used for "brushes" on electrical motors. They make electrical contact and last a long time. I'll let you know if it works. Thanks
68 Vetteman
Old Feb 20, 2011 | 09:42 AM
...Roger...'s Avatar
...Roger...
Seems like were always having to fix all these new parts #%&*.
Next we'll have to use the brake switch to key a relay to turn on the brake lights !
Old Feb 20, 2011 | 09:50 AM
68vetteman's Avatar
68vetteman
I thought about that fix too.
68 Vetteman
Old Feb 20, 2011 | 08:35 PM
68vetteman's Avatar
68vetteman
Just a quick update. I milled a new switch piece for the contacts from brass, heavier than original. Back together and seems to be working. Just don't know for how long.
68 Vetteman
Old Feb 20, 2011 | 11:28 PM
7T1vette's Avatar
7T1vette
What you did has to be better than that 'junk' part. Nice work. Hope it lasts.
Old Aug 7, 2011 | 12:49 AM
done4fun's Avatar
done4fun
i am disabled and have to have my 16 year old son take out brake switch on my 81 vette.....what holds it in place as i dont know where to get diagram...thanks in advance for anyone who may ne able to help me....im sure i will be frustrated as i used to do everything on my own but since i broke my back thats the end of those things....i can get into care when i am able to drive it but have to like roll out!!!!god bless you all.
Old Aug 7, 2011 | 12:56 PM
PRNDL's Avatar
PRNDL
68 Vetteman
are you working on a 68 corvette brake light switch?
ie, this type of thing?
Old Aug 7, 2011 | 01:42 PM
7T1vette's Avatar
7T1vette
I don't remember the '68 switch having a lever. I thought it was same as the later C3's...plunger switch that has just one sheet metal nut that screws onto the threaded plunger shaft. Easy to remove and test with an ohmmeter. Remember that the plunger makes contact when released and breaks contact when the plunger is depressed.
>>>Remove battery cable before working on that switch. 12v. power is going to it even with key out of ignition.
Old Aug 7, 2011 | 01:43 PM
...Roger...
Would it help though ? Sorta like the cap for points ? I realize it is installed differently,the brake cap goes from terminal to terminal where the points cap goes terminal to ground.
Old Aug 7, 2011 | 02:42 PM
DZRick's Avatar
DZRick
The '68 brake switch was another one year only item.
Old Aug 7, 2011 | 03:19 PM
PRNDL's Avatar
PRNDL
Sorry, this is an old thread that was brought up by done4fun who is looking for some help on his 81. Any ideas? I guess best advice to start was to disconnect the battery cable!
Old Aug 7, 2011 | 05:06 PM
Lupigiato's Avatar
Lupigiato
Just replaced mine back in June. One year part on the 68.
Old Aug 7, 2011 | 06:16 PM
manfroni's Avatar
manfroni
i ordered a replacement switch for my '78 and when I looked at how crappy it was made, I took the old one apart, cleaned it and sanded the contacts. works perfect for over 5 years. easy to do!
To Brake light switch
