Tach - just went out..
Old Feb 23, 2011 | 11:23 AM
ultimix's Avatar
ultimix
Default Tach - just went out..
Driving my 71 convertible in work today... when I looked down - the tach went out.
Any ideas on the first place to look??
thanks
MArk
Old Feb 23, 2011 | 11:40 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by ultimix
...Any ideas on the first place to look?...
Drive cable.
Old Feb 23, 2011 | 11:45 AM
71 Green 454's Avatar
71 Green 454
Gears.....I just replaced my distributor shaft and gear.
Old Feb 23, 2011 | 11:59 AM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Drive cable.
Lost mine a number of years ago and it turned out to be the cable. Check that you don't have a 90 degree bend off the dist.
Old Feb 23, 2011 | 01:29 PM
joewill's Avatar
joewill
1. distributor gear
2. tach cable itself
3. cable came loose and is disconnected
4. Tach itself went out.
1,2 and 3 are easy... if 4, then dash has to come out.. yuk...
Old Feb 23, 2011 | 01:42 PM
71 Green 454
If you disconnect the cable at the distributor and turn it with your fingers you should see the tach operate. If it does, then it's probably worn gears at the input, main shaft, or in my case, both.
Old Feb 23, 2011 | 05:00 PM
Alan 71's Avatar
Alan 71
Hi 71G454,
Do you turn it clock-wise or counter; and can you spin it fast enough with your fingers to get the needle to move?
Regards,
Alan
Old Feb 23, 2011 | 06:29 PM
71 Green 454
Originally Posted by Alan 71
Hi 71G454,
Regards,
Alan
Hi Alan, I don't remember which direction, but it doesn't take that much to see the needle move. I can lean over while turning the cable and see the needle move.
In my case, both gears were worn so I had to replace the shaft and connector gear.
Dave
Old Feb 23, 2011 | 07:21 PM
Alan 71's Avatar
Alan 71
Hi Dave,
Thanks for the info update!
Regards,
Alan
Old Feb 23, 2011 | 08:32 PM
...Roger...'s Avatar
...Roger...
Sometimes the cable is slightly short and after a period of time the square end rounds off and the tach stops.
Another if your a lucky person idea, is the brass wears and the 2 gears get away from each other and the tach stops.
Old Feb 23, 2011 | 09:45 PM
my 76 ray's Avatar
my 76 ray
I attached a reversable drill to my cable to test it on my '74. Run the drill in reverse.
Old Feb 23, 2011 | 10:56 PM
ultimix's Avatar
ultimix
thanks - will check these out
Mark
Old Feb 23, 2011 | 11:41 PM
madeintheusa's Avatar
madeintheusa
The 74 i just got the wife had a bad tach drive cable 20 bucks and its back to life.
Old Feb 24, 2011 | 12:17 AM
azza2u's Avatar
azza2u
If it is the cable make sure you get a good solid replacement one. The PO of my car had thrown in one with a nylon end where it goes in the dissy and it sheared off after about a month.
Old Feb 26, 2011 | 02:27 PM
ultimix's Avatar
ultimix
Looks to be the cable - when I took it off from the distributor the end was all uncoiled and looked to be spun out.. the part that spins in the cable was not together.
Here is the question - which cable do I get with my Mallory distributor?
this one?
http://www.zip-corvette.com/ProductDetails/ProductDetails.aspx?pid={76061DF4-4906-44D0-9E5C-D03EE4351448}&gid={27172F36-D05C-4C67-91AA-D7AD47169E34}&pname=69-74+Tachometer+%26+77-82+Upper+Speedometer+Cable&Referer=&Alia s=&ptct=SGR-SR&CTitle=&
Old Feb 27, 2011 | 07:25 PM
ultimix's Avatar
ultimix
Anyone??
Old Feb 27, 2011 | 08:24 PM
Paul L's Avatar
Paul L
Roger,
Been there, seen that (cable on top). Ever wonder why GM put a ferrule at the tach end so you just can't pull that inner cable out and replace it from the distrib end?
To Tach - just went out..
Old Feb 27, 2011 | 08:27 PM
ultimix's Avatar
ultimix
Originally Posted by paul 74
Roger,
I was wondering that myself.. how to get the tach connect end of the cable through the firewall..
Old Feb 27, 2011 | 08:40 PM
Paul L's Avatar
Paul L
You pull out (and destroy, hard to avoid) the old tach grommet and buy a new one along with the new cable.
http://willcoxcorvette.com/advanced_...s=tach+grommet
Old Feb 28, 2011 | 09:51 PM
ultimix's Avatar
ultimix
Thanks - sorry getting both - but how would you run the cable though the gromment with the metal end already installed on the cable or will that be easy to figure out once I get both parts??
Mark
