Bracket - A/C ?
Old Feb 24, 2011 | 08:31 AM
daanbc's Avatar
daanbc
St. Jude Donor '12
Default Bracket - A/C ?
Can anyone tell me if this bracket is deff. needed. The black bar that goes from the back of the A/C comp. to a bolt on the manifold (under the carb). The A/C is held in place by a cast iron bracket on the bottom, and anothe bracket on top. I took the rear one off, because I knew it was going to be in the way of some new "tall" valve covers im getting. If it is needed, then I'll have to get one made up. But as of now the A/C isn't moving at all.
Old Feb 25, 2011 | 11:41 AM
daanbc's Avatar
daanbc
St. Jude Donor '12
Nobody? I just would like to know if this is needed or not. Has anybody removed theirs? Thanks.
Old Feb 25, 2011 | 11:54 AM
restoreral's Avatar
restoreral
My opinion is that if GM could have saved a dime by leaving it off they would have. It was not put there for it's looks. I would not leave it off myself. JMHO
Old Feb 25, 2011 | 12:10 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
Very good point. I guess I'll have to have a machinist make one up for me.
Old Feb 25, 2011 | 01:22 PM
corvetteload's Avatar
corvetteload
Honestly, I had a 75 and it didn't have that bar. Do you have the long style or the small type compressor? A 75 had the long and didn't have that.
Old Feb 25, 2011 | 01:29 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
Its the short pan style. It is just shy of the pic. (cut off)
Old Feb 25, 2011 | 01:59 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
I saw in a recent thread that the upper support on an 82 goes to the exhaust manifold instead of the intake.
Maybe research that and adapt an 82 support....
Old Feb 25, 2011 | 03:58 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I'm thinking that bar is for a big block. I had a 68 Impala 396 with factory air and it had the bar.
EGR block off plate is also not stock.
Old Feb 25, 2011 | 05:54 PM
KapsSA's Avatar
KapsSA
That brace is used on all 77-81 Vettes with the R4 compressor.
Like I mentioned above, the 82 brace may be different.
There's also a similar lower brace that attaches near the fuel pump.
Old Feb 25, 2011 | 09:16 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
(I'm thinking that bar is for a big block. I had a 68 Impala 396 with factory air and it had the bar.
EGR block off plate is also not stock.)
I did the EGR block off.
(That brace is used on all 77-81 Vettes with the R4 compressor.
There's also a similar lower brace that attaches near the fuel pump.)
Thanks, All of the other brackets are on it. I had to move this one due to taller valve covers.
To Bracket - A/C ?
