brakes sticking
Old Feb 27, 2011 | 08:28 PM
Phil5519's Avatar
Phil5519
Cruising
Default brakes sticking
I have a 76 and after driving and everthing heats up the front brakes start to stick.
do the front calipers have to match. Driving me nuts
Thank You
Old Feb 27, 2011 | 09:07 PM
Kevin_73's Avatar
Kevin_73
Cruise-In X Veteran
St. Jude Donor '09-'11
Thank You
You probably need new brake hoses.
When they get old the flexible rubber brake hoses tend to swell and then the springs in the calipers don't have enough strength to push the fluid back through them. They basically can become like a one way valve.
Old Feb 28, 2011 | 07:51 AM
muskegonbrake's Avatar
muskegonbrake
Supporting Vendor
That is the most common cause for sticky brakes. I have hoses ready to ship, let me know if we can help.
Andrew
800-442-0335
Old Feb 28, 2011 | 12:29 PM
builder's Avatar
builder
I would inspect all of the brake calipers and lines as well as the master cylinder. Every time I have a brake issue, I make sure nothing else is going to be a problem. If the vehicle sits a lot, the calipers pucks could be sticking from corrosion inside them.
Old Feb 28, 2011 | 01:51 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Define "sticks." C3 brake pads are in contact with the rotors at all times.
Old Feb 28, 2011 | 05:00 PM
glackore's Avatar
glackore
Most likely the brake hoses. As others suggest, check all of the components. It is a simple process of elimination.
To brakes sticking
