Ground for amp?
Old Mar 4, 2011 | 09:24 PM
ozzyrulesme's Avatar
ozzyrulesme
Default Ground for amp?
Where do you ground your amp at? I have.74.
Thanks...
Old Mar 4, 2011 | 09:28 PM
Cajun-in-tx's Avatar
Cajun-in-tx
Thanks...
The battery.
Old Mar 4, 2011 | 09:37 PM
ozzyrulesme
Thought of that didn't know if there was another place people used instead. Thanks..
Old Mar 4, 2011 | 09:38 PM
another-user's Avatar
another-user
i use the battery also
Old Mar 4, 2011 | 09:45 PM
Cajun-in-tx
Since the car is fiberglass and the battery is in the back it makes it easy.
Old Mar 5, 2011 | 12:35 PM
Paul L's Avatar
Paul L
Both power (+, fused) and ground (-) are at the battery.
Old Mar 5, 2011 | 09:31 PM
onaqwst's Avatar
onaqwst
battery and the frame... have 2 points... helps with any sort of hissing issues
Old Mar 6, 2011 | 05:10 AM
dgood's Avatar
dgood
Ozzzy,
I went through the rear fender well (rubber grommet) on driverside, right below the rear speaker down to the frame and bolted the ground there. I don't have any hissing issues with my stereo either. The ground wire that came with my install kit was pretty short and would not reach my battery so I just ran it to the frame.
To Ground for amp?
