1980 corvette transmission question...
Old Mar 10, 2011 | 01:05 PM
DarksideKP's Avatar
DarksideKP
Default 1980 corvette transmission question...
Hi everybody. First time poster here and I have a question. Ok so I have a 1980 corvette with a 350 V8 bored over. 60, with a .458 cam, a dart highrise manifold, edelbrock 650 cfm thunder series carb, hooker super comp headers with sidepipes (no baffles), a 3.73 gear and unfortunatley a 3 speed automatic. I'd really like to put a manual transmission in but I would like to know which ones would work with my car. Really looking for a 4 speed. Any help would be appreciated.
Old Mar 10, 2011 | 01:58 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I'm not a real specialist in these matters, but I'll go out on a limb and say that your car most likely would have come with either a Borg Warner or a Saginaw 4 speed, had it originally been a stick shift car.
If you're going to go through the work of a conversion, why not consider a modern 5 or 6 speed, for the added drivability?
Old Mar 10, 2011 | 02:04 PM
7T1vette's Avatar
7T1vette
If you are going to install a manual 'box' in the car, you should install a 5 or 6 speed gearbox with at least one overdrive gear. Some 6 speed units have two overdrive gears (approx. .8 and .6 ratios, compared to a single .67 overdrive 5th gear in a 5 speed box). With a 3.73 [or higher] rear gear, highway driving is much more comfortable, economical, and engine-saving if you have an overdrive tranny in the car.
Old Mar 10, 2011 | 02:10 PM
DarksideKP's Avatar
DarksideKP
Looking for something to use more for road racing applications. Fuel milage isn't really a concern nor is cruising. My vette no longer has any luxuries. Its gone on a serious diet...
To 1980 corvette transmission question...
