79 Driver window guestion
Old Mar 14, 2011 | 10:09 PM
vish2000's Avatar
vish2000
Default 79 Driver window guestion
Newby here, the window moves side to side, whats missing?
Old Mar 14, 2011 | 10:16 PM
texaswilkins's Avatar
texaswilkins
Look in from the top and you should see some black fuzzy bits against the inside edge of the glass. Tighten or replace as required. While you are looking in from the top wiggle the window and you can see if something lower is moving. Take off the door panel and tighten anything that is loose.
Bill
Old Mar 15, 2011 | 12:36 PM
Wuttin's Avatar
Wuttin
Bill
Agreed. Black fuzzy bits are important but there are many other points where looseness can occur. You need to open it up and carefully troubleshoot what you have. Make sure when you reassemble that the glass is in the vertical position and adjusted properly before putting the door panel back on (I get to take mine apart again...guess why...).
See if these help...from the 79 Assembly Instruction Manual (AIM). Well worth the investiment, used copy will set you back around $30 on a good day.
Best of luck, Steve
To 79 Driver window guestion
