The windsheild on my 72 is leaking, what is the best way to take the windheild trim off to inspect where the leak is coming from and the best way to repair it.
My advice would be to purchase the 72 assembly instruction manual (AIM). It shows how the trim was installed which is helpful when removing it.
What to use to fix the leak could depend on what you find.
Basically you will have to take off the pillar post weather-strip and retainer then the pillar post molding. Then to get to the top remove the small upper windshield molding if you need to go further than that then the T-Top trim which will involve removing some interior trim . If you cannot find your problem there it may be under the windshield itself I would be sure that the leak was coming from the windshield before starting this adventure. If it is coming from there you are probably not going to like what you find.
Best of luck
