2nd gear & reverse
Old Mar 17, 2011 | 06:43 PM
fastrad's Avatar
fastrad
Default 2nd gear & reverse
I installed a 4 speed in a 73. Shifter was aligned, from time to time the shifter will be stuck in 2nd and reverse. Adjusted the throw on 2nd and the throw on reverse. It appears that the shifter tries to move the 1st and 2nd rod when trying to go into reverse. Thinking about rebuilding the shifter but everything seemed tight. Any Suggestions would be appreciated.
Old Mar 17, 2011 | 07:49 PM
Phil Zell's Avatar
Phil Zell
Rick, I have another shifter if you want to try it.
Let me know
Phil
