Help!
Old Mar 23, 2011 | 12:59 PM
ICEMAN59's Avatar
ICEMAN59
Default Help!
I want to shim my trailing arm where my tires don't rub so I can bring the car to an alingment shop and save towing expense and I can't remember where they go.
Old Mar 23, 2011 | 02:32 PM
Roco71's Avatar
Roco71
The shims go on either or both sides of the trailing arm where the bolt goes through (the busings) to the frame. Are the tires rubbing the trailing arms?
Old Mar 23, 2011 | 02:44 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Shimming the trailing arms is for correct toe-in settings. It isn't meant to provide tire clearance.
Go slowly.
Old Mar 23, 2011 | 03:09 PM
7T1vette's Avatar
7T1vette
If you've got some big-a$$ tires on there, you need offset trailing arms..not shims.
Old Mar 23, 2011 | 03:19 PM
joewill's Avatar
joewill
if your tires are rubbing then there is someting really wrong...
Old Mar 23, 2011 | 03:20 PM
Roco71's Avatar
Roco71
That’s what I’m think’n or wheel spacers
To Help!
