which gears
Mar 26, 2011 | 02:12 PM
which gears
So I'm having the block in my 81 bored and balanced adding new cam and heads and hope to be around 325 hp not a race car by any means but I do want it to go when I step on the gas. So everyone is telling me I need gears but I have no clue what to go with. I saw a couple on mid america 3:55 and 3:07
Mar 26, 2011 | 03:52 PM
2015 C2 of Year Finalist
Mar 26, 2011 | 05:36 PM
Quote:
Originally Posted by
Nowhere Man
auto or 4 speed.
It is a 3 speed auto but, I have a 4 speed auto I plan to do after the motor and gears are done
Mar 27, 2011 | 03:26 PM
Are these the ones for $1200? Just a fyi, that with 3.55 gears, at 65mph, you will probably be reving @ 3000rpm. If you dont mind that.
I would suggest talking to a local guy and getting some more info and prices. Contact Gary in CT, besides steering he also rebuilds rearends.
Might be more benefical to speak to someone that can make the change and you know the quality.
Good luck. My .02
PM sent
Mar 27, 2011 | 06:17 PM
riarms
if your going to have an over drive gear, go all the way and get 3.70s
Mar 27, 2011 | 06:19 PM
Cruise-In III Veteran
St. Jude Donor '05
what does the cam manufacturer suggest for the cam you chose?
Mar 28, 2011 | 11:46 AM
SmokedTires
It dosent say anything about gears on the spec sheet
Duration 276/284, Lift .488/.509,
Mar 28, 2011 | 11:49 AM
karol
Good luck. My .02
I think they are 1400 but 400 is a core charge. is Gary in CT a member here?
Mar 28, 2011 | 12:06 PM
Part Number: 119821 Grind Number: HR-276-2S-12 IG
Engine Identification:
Start Yr. End Yr. Make Cyl Description
1957 1987 CHEVROLET 8 HR-276-2S-12 IG camshaft - Ch. 262-400 V8 57-87
Engine Size Configuration
262-400 C.I. V
Valve Setting: Intake - .000 Exhaust - .000 Hot/Cold - HOT
Lift: Intake @Cam 325 @Valve 488 All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 339 @Valve 509
Rocker Arm Ratio 1.50
Cam Timing: TAPPET @ .004
Lift: Opens Closes ADV Duration
Intake 27 BTDC 69 ABDC 276 °
Exhaust 75 BBDC 29 ATDC 284 °
Spring Requirements:
Part Number 99846
Loads Closed 125 LBS @ 1.800 or 1 51/64
Open 350 LBS @ 1.280
Recommended RPM range with matching components
Minimum RPM 1600
Maximum RPM 5800
Valve Float 6500
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake 0 BTDC 34 ABDC 107 214
Exhaust 48 BBDC (6) BTDC 117 222
Mar 28, 2011 | 01:52 PM
St. Jude Donor '09
riarms
He used to be, but now hangs out at the DC site I beleive. You can check there or maybe someone here can PM you his contact info.
