Astro Ventilation
Old Mar 27, 2011 | 12:55 PM
Todd M's Avatar
Todd M
Default Astro Ventilation
Ok,
I have 2 1974 Corvettes. The first I bought has no motor and because I discovered it needed more than just dropping a motor in, it has sat for 2 years. So I bought a secondone thinking I was getting a deal. A lot of work went into it, but It has some serious body alignment issues. But I digress.
The first car had no air-conditioning. It has an open set of vents in the rear deck and says Astro Ventilation on the windows. The second car has non-working air-conditioning and the rear vents have fiberglass covers glued on underneath. Now this makes sense to me. I would guess then that all air-conditioned cars were blocked off.
Both cars say Astro Ventilation on the window. If the vent is blocked off would an air-conditioned car have had the Astro Ventilation label as well?
Old Mar 27, 2011 | 01:02 PM
nutsy's Avatar
nutsy
yes it does but its non fuctional at least on the 72s.
Old Mar 27, 2011 | 04:57 PM
Alan 71's Avatar
Alan 71
Hi Todd,
Nutsy is right. A/C cars had the block-off plates.
The side glass said Astro whether the car was std or had a/c.
Regards,
Alan
Old Mar 27, 2011 | 09:19 PM
Tom73's Avatar
Tom73
Are they coupes or convertibles? On the coupe with a/c, the vents are blocked off as they are located above the interior storage compartment. On verts with a/c, they are open as they are located further to the rear and are behind the storage compartment (you can look through them and see the ground).
Old Mar 28, 2011 | 12:47 PM
Todd M's Avatar
Todd M
They are both coupes. Thanks for the info. I am trying to learn a little at a time here. Both cars have a lot of issues. Neither has an original drivetrain. I hope to build a mildly modified car one day. If all was equal would you start with the 4-speed A/C car (Green) or the automatic non-a/c car (White). The 4-speed non-ac car is the most complete currently but I fear has some serious body alignment issues.
To Astro Ventilation
