So I've started another project. This time it is an LS powered '73 roadster. Not doing a restoration but resto-mod. Flares, sidepipes, 6 speed. And I'm looking for roll bar ideas. I bend up a piece of 1/2" EMT just to play with the profile and location
Would like to attach to the lock pillar but it may be too close to the seat headrest.
I haven't ruled out bonding the decklid to the body. Won't ever have a soft top. Other then being able to load groceries back there I don't see the need to do hinges, latches etc.
Looking for pictues of roll bars that have turned out well. And I guess pictures of bad ideas are good too.
For one thing puting a single loop bar in a "convertable" is I guess better than nothing but not really. I have rolled vehicles in all positions, some multiple times. I am very thankfull for having a complete cage, 8 point and a 10 point. Triagulation and frame mounting is the key to survival. I have always used 2.25 X .25 thickness wall seamless tubing. Carefull welding with gusset bracing. Good luck Al
I agree and I considered at least a 4 point but it limits access. This is a weekend cruiser and I might want the wife to go for a ride. Not sure I could convince her to crawl in. I like the looks of a Shark Bar but would like some function beyond a place to anchor the harness.
Definatly find a way to mount properly to the frame. I remember seeing a Jeep flip over and the roll cage went through the floor of the body pinning the occupants, Seriouse injurys but they luckily lived. I flipped over backwards once with my son climbing a limestone wall in our full size bronco. We fell nearly 15' straight down onto the top/cage. It held up as well as our harnesses. Front w/s broke but after rolling back over and a little coaxing the engine started back up and we drove out. That was when i respected the true roll cage. Good luck Al
