Underdrive pullys?
Old Mar 28, 2011 | 05:53 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
Default Underdrive pullys?
Could someone explain how a underdrive pully would give you more H.P. . My friend gave me a underdrive pully set -Billit/March for my B-day today. The water pump and Alt. pullys are about the same size. But much lighter. The crank is REAL small compared to my stock. I started to put them on. I'm waiting till tomm. to get smaller belts. Thanks!
Old Mar 28, 2011 | 06:23 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Pretty simple. All of the accessories take power (HP) to run them. By spinning them slower, they will take less HP. By putting larger pulleys on the accessories or a smaller pulley on the crank, the accessories will take less HP from the motor. They will also run slower and deliver less water flow or electrical power.
Old Mar 28, 2011 | 06:30 PM
toddalin's Avatar
toddalin
If the driven pulley is made larger relative to the driving pulley, it turns slower. If a driven item is turned slower, it reduces friction at all of the bearings involved, as well as losses directly through the pulley friction.
The possible downside is that your alternator and water pump turn slower and therefore produce less amps and move less water to keep your engine happy.
I use modest underdrive pulleys in my MillerSpeed Gilmer system and have no problem with either amps or water temps, but I do use a 100 amp alternator and a high performance aluminum water pump.
Old Mar 28, 2011 | 07:49 PM
Mike Ward's Avatar
Mike Ward
The flaw in the logic of these pulleys is that the accessories really don't consume much power to start, with so slowing them down slightly won't make much, if any, difference.
In most cases, having a alternator, PS pump, water pump or cooling fan turning too slow at idle is not a good thing.
Old Mar 28, 2011 | 08:25 PM
thegazman's Avatar
thegazman
Default thegazman
I think if you look at the water pump pulley, it is slightly larger than stock giving you about the same water flow. The only place that you don't need as many rpm's to function properly is the power steering pump and the A/C compressor. What the heck, put it on it looks good.
Old Mar 28, 2011 | 09:02 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
Im not worried about the Alt. I replaced it a month ago with a 100 or 120 amp. As for cooling, I already have a new Big block rad, new fan and clutch. The car runs at 180 all day. So even IF it does go up a little, I think the car can handle it. Thanks everybody....Will post pics once it's all done with the new hoodliner in place.
Old Mar 28, 2011 | 09:07 PM
TPI BOY's Avatar
TPI BOY
Old Mar 28, 2011 | 09:48 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
My opinion is that the gains are mostly found during acceleration. Think of all the accessories as distributed flywheels (such as the alternator rotor, w/p impeller, and the driven pulleys). Reducing the drive ratio slows down the individual acceleration rates. Using less of the engine's power to accelerate the accessories leaves more to propel the car. (The number is small, but often it's free for the taking.)
Old Mar 29, 2011 | 08:05 PM
68/70Vette's Avatar
68/70Vette
The pulleys on my GM Performance Parts catalog Serpentine kit were intended to be used in the 1991 and 1992 Camaro and Firebird (and probably some other cars.) I'm pretty sure the crank pulley was sized to spin the water pump and alternator at speeds to care for the car going in stop and go traffic in the very hot weather of the Southern US.
My 68 isn't going to be driven under those conditions. I installed an underdrive March pulley to reduce alternator and water pump speeds. No problem. The car runs a cool 180 degrees F, but at idle, with the electric fans blowing, the alternator cann't keep up at engine idle adn I see a sllight battery discharge. No problem when the car is moving.
To Underdrive pullys?
