1981 corvette carb
Old Mar 28, 2011 | 10:03 PM
mcaiella's Avatar
mcaiella
1st Gear
Default 1981 corvette carb
hey i have a 1981 corvette with a 350 stock just wondering if the stock carb is a 600 cfm and if it is what will i gain by putting a 600 cfm edelbrock
thanks
Old Mar 28, 2011 | 10:29 PM
terry82's Avatar
terry82
if your computer is hooked up ,it wont like the edlebrock.you will not gain anything .are you having a problem with the stock carb?
Old Mar 28, 2011 | 11:42 PM
7T1vette's Avatar
7T1vette
The Q-Jet is a 750cfm carb...some flow up to 800cfm. But, your '81 carb has an electronic fuel metering device that is part of the earliest computerized engine management systems placed in a Corvette. That system was for one year only and was replaced the following year by twin throttle body fuel injector units (82 & 84 CrossFire induction system). The carb, distributor, O2 sensor and ECM all interconnect to help regulate the fuel flow and minimize emissions. If it still works, don't mess with it. Just my .02...
P.S. You can modify the engine (cam, pistons, heads, headers), but that control system will still do a fine job of engine management, if it is still operational.
Old Mar 29, 2011 | 10:14 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by mcaiella
...what will i gain by putting a 600 cfm edelbrock...
Nothing.
Rebuild your 4ME.
To 1981 corvette carb
