68 corvette wipers
Old Mar 30, 2011 | 10:46 AM
gojoe45's Avatar
gojoe45
2nd Gear
Default 68 corvette wipers
Does anyone know why my wipers will still turn on without the limit switch for the wiper door not made up thanks
Old Mar 30, 2011 | 11:55 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Has the limit switch been bypassed or otherwise fiddled with by Bubba?
When the wiper door is nearly completely opened, the plunger trips the limit switch and turns on the wiper motor.
Old Mar 30, 2011 | 06:09 PM
...Roger...'s Avatar
...Roger...
This link might help.
http://willcoxcorvette.com/repairand...lp.php?hID=293
Old Mar 30, 2011 | 09:00 PM
gojoe45's Avatar
gojoe45
2nd Gear
Default Bubba
[BQUOTE=Easy Mike;1577206033]Has the limit switch been bypassed or otherwise fiddled with by Bubba?
[/QUOTE]
No Bubba didnt fiddle with it. Unplugged stilloes the same
Old Mar 31, 2011 | 01:14 PM
Easy Mike's Avatar
Easy Mike
You can check the wiper override under the steering column, but it should not work if the wiper door is closed. The override is used to stop the wipers on the windshield to allow for adjustments or blade changes. It is not supposed to power on the wipers.
Old Mar 31, 2011 | 07:30 PM
DZRick's Avatar
DZRick
When you say not made up, do you mean it's not plugged in?
If it is plugged in have you checked the limit switch with a continuity tester to make sure the switch actually works? It may be that the switch is stuck in the closed position.
To 68 corvette wipers
