Is it bad to wash/degrease a L-48 engine???
Old Mar 30, 2011 | 10:52 PM
Mikey1968's Avatar
Mikey1968
Default Is it bad to wash/degrease a L-48 engine???
I have heard mixed reviews. Just picked up a real original, and filthy '80. Tons of dirt, grime and grease. Would like to clean it up a bit.
I know this was a no-no with many of the C4's, but I was thinking maybe I could just cover up the distributor, altenator, and carb, and wash it cafefully.
I heard it is ok to do, but also that you shouldnt.
What do you guys think? Curious.
Dont want to regret doing it.....
Old Mar 30, 2011 | 11:19 PM
Spocc's Avatar
Spocc
i covered exactly , those 3 things (with a plastic bag) that you mentioned...
did the spray thing with a can of degresser...then sprayed it down with a garden hose...then a quick blast down a country backroad
no more smell from engine & it looks better all clean
Pete
Old Mar 30, 2011 | 11:22 PM
BARRY L-48's Avatar
BARRY L-48
Default Engine cleaning
I owned an 80 and degreased the engine and under hood area with no problems,of course cover the carb and distributor and do not apply too high a pressure on any wiring or components, I have found in the past that degreasing motors or trannys have led to fluid leaks as the built up grease/dirt can actually stop a leak but then again we like to have a clean under hood area for show and to work on. Also cover your alternator,just my 2 cents worth!
Old Mar 30, 2011 | 11:29 PM
I'm gone's Avatar
I'm gone
I've done this also and never had any problems, I used a garden hose so not much pressure, I also didn't want to splash the degreaser on the paint.
Old Mar 30, 2011 | 11:45 PM
7T1vette's Avatar
7T1vette
If you just want the engine/compartment done, the degreaser and $5 worth of quarters at the local car wash will get the job done. (Psst... If you go on a rainy day, no one will care that you're 'hangin' out' in there too dang long.)
Old Mar 31, 2011 | 12:30 AM
Mikey1968's Avatar
Mikey1968
Thanks for the input. Gonna do it this weekend. Supposed tobe nice and sunny.
Old Mar 31, 2011 | 01:00 AM
jeffp1167's Avatar
jeffp1167
Never use degreaser on a L-48 !!!!!!!!!! it will melt unlike the L-82
Old Mar 31, 2011 | 02:36 AM
tfi racing's Avatar
tfi racing
Remember to bring along a screwdriver and the WD-40,water will get into that distributor cap no matter what you cover it with,ask me how I know...After the first major cleaning,it will be a breeze to keep it clean in the future.
Old Mar 31, 2011 | 12:48 PM
builder's Avatar
builder
I would try to do it when engine is cold also.
Old Mar 31, 2011 | 01:36 PM
noonie's Avatar
noonie
The safest is to pull the plugs before trying to restart. Can save you from a bent rod if water somehow got inside.
Old Mar 31, 2011 | 03:48 PM
builder's Avatar
builder
I just pull the wires off the plugs, spray them (plugs and wires) down with WD-40 and then blow them dry with compressed air. Same with a distributor cap.
Also, keep in mind that the engine degreaser can ruin the engine compartment paint.
Old Mar 31, 2011 | 05:05 PM
ElCid79's Avatar
ElCid79
Huh?
Old Mar 31, 2011 | 06:41 PM
Vette5.5's Avatar
Vette5.5
No matter how you decide to clean thing's up, it's a good idea, as much easier to find where leak's are originating from now, or one start's up later.
Old Apr 1, 2011 | 12:32 AM
Milton Fox's Avatar
Milton Fox
St. Jude Donor '09-'10-'11
You can also use straight Dawn dish washing soap and a few brushes to do most of the clean up and not have to use a car wash pressure system - just a garden house.
Old Apr 1, 2011 | 02:13 AM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
Originally Posted by ElCid79
Huh?
Yup, L-48s will melt. They are designed to be greasy, unlike an L-82 or L-46 or L-79, etc.
if it was an L-46, i would just get some Gunk Engine degreaser (not the foamy engine brite stuff),and spray liberally, and wash off with a high pressure hose. Done it over a hundered times, with care to keep the dizzy dry, or at least bring enough dry rags to dry out the inside of the cap.
But never an L-48.
Doug
Old Apr 1, 2011 | 07:28 AM
79L48's Avatar
79L48
But never an L-48.
Doug
You made me laugh twice!
Seriously, though... I think some of the grease and gunk is holding things together in there. She'll get cleaned during the frame-off. In 20 years.
Old Apr 1, 2011 | 08:21 AM
newbie2vette's Avatar
newbie2vette
If you really want to eliminate all the grease and dis-bond the dirt attached with it. Use the white gas used on the camping stove, put it in a spray bottle and spray afterwards just use compress air to blow away and dirt. the white gas will breake down any petrolium base produce and will dry instantly leaving you with clean dry surface. If the dirt is thick the grease or oil keeping it together will breake down and can be remove with air.
To Is it bad to wash/degrease a L-48 engine???
