Speedometer help needed 73'!
Old Apr 3, 2011 | 08:54 PM
Steve's '73's Avatar
Steve's '73
Default Speedometer help needed '73!
Alright guys, hope you can help.
Speedometer quit working, so I removed the cable and noticed that the plastic portion that enters the speedometer had broken inside the speedometer. Proceeded to take apart the dash and remove the speedometer so I could get the broken portion out and install a new cable. No luck, I can't get the plastic portion out of cable housing inside the speedometer. It seems to have twisted off inside and isn't budging. Is there any way to push the broken plastic piece out?
I had the speedometer rebuilt by Wilcox last year and it’s been working fine until this happened.
Steve
Old Apr 3, 2011 | 08:58 PM
forman's Avatar
forman
dental tools
Old Apr 4, 2011 | 10:59 AM
oldsarge's Avatar
oldsarge
Originally Posted by forman
dental tools
You just have to pick at it until it loosens up and it will come out.
Old Apr 4, 2011 | 10:50 PM
shrekviper's Avatar
shrekviper
dental tools
That's exactly what happened to mine. I used a small dental pick as well. If it's really stuck you could drill a very small hole in the plastic and put in a equally small screw in the hole, then pull. That was my plan B if the pick didn't work.
Old Apr 5, 2011 | 05:31 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I use what is called bowden cable. It is a spring wire about 1/32" just like what is used in a lawn mower or on a heater control cable.
I take my wire cutters and make little pinches on the side to create teeth.. I then this up with a torch and insert it in the back of the head. When it cools down the plastic piece pulls out with it.
What ever you do don't move that adjustment lever on the speed cup too..
Willcox
To Speedometer help needed 73'!
