I was reading a few post where the shoud was cut in half to make it easier for removal. Heres my question. Do you cut it in half across say east to west or do you cut it in half down the center from North to South. I know someone is goning to say man thats a dumb question but I would rather be safe than sorry. Thanks Richard
I did my 75 the same way well not sure what to tell you to do. I cut mine where i had enough bolts to hold the top and enough to hold the bottom and to tell you the truth you cant even see the cut marks My car is in storage or id go out and look at it for ya but i got about a week or so till I unbury it.
Seems like its right in the middle.
It made putting in my new rad so much easier.Put the bottom hose on the radiator before you install it (you wont be sorry).
Definatley cut horizonal.
Unless your name is Bubba, don't cut it at all. Plenty of us have removed and replaced the shroud without cutting it.
Actually Cheverolet thought it was such a good idea they started using a two piece.
If done correctly he wont have to take any of the front end off and that was the main reason i did it.I was smashing the cardboard that way around my radiator I no way wanted to take off the nuckle or any other part of the front end.So i trimmed her like a barber /bubba Im so sure you could not see my cut that ill buy you a 5 dollar subway sandwich. got any friends in say Columbus Ohio?? Just a friendly throw down.
Look...for those of you who do not have A/C and and auto tranny, don't pretend to know what you're talking about. The one-piece plastic [full-face] shroud is a real PITA to get out of there. It's almost impossible without breaking it to begin with.
If you decide to cut it, just find the middle of the very bottom of the shroud and cut it from front-to-back. Then you can more easily bend/flex the POS to get it out of there (and back in). While out, just make a little joiner plate to fit under the area you cut. Drill a couple of holes on each side and install some T-nuts on the inside of the shroud in those holes. Then, you can install the plate and screws from the bottom to put it all back together. If you do it right, it won't even be noticible from the topside.
I have a shop installing my aluminum radiator, the thing about it is if I cut it now down the road I will not have a PITA. If i DONT I will bang my head up against a wall but because my car is a custom widebody I see no sense in preserving plastic,,,,,,now wheres the blade. ok I wont cut it this time but if it ever has to come out down the road I will. Thanks for everyones advice and by the way it is an automatic with a\c. Richard
I am by no means a car guy, I work on computers all day long. I struggled and was able to get the shroud in and out of my 79 with a little bit of effort. Just remove the fan blade. That really helps.
When was that? I can't recall any stock C3 shrouds which come in halves.
Mike you got me on that one they did not do it on the C-3 only later on the c-4 .
I did mine and Id do it again.
Come on I have A 75 Why not.
My Rad went in like a charm.with it split and you cant see the split.
My only regret was not putting on the bottom hose to the Rad first .should have done that, as is I had to buy another Wrench to add to the collection.
Call me Bubba but back "in the day" before computers I cut a chunk out of mine to get it back in
As much as I like to do things the right way, IMHO the shroud was installed with the intent that it would never come out unless the water lump was first removed.
IMO, If you do a neat job that has a nice "finished" look to it, only the purists/NCRS crowd will find fault, and your knuckles and the radiator will thank you
I have split the shroud at the bottom, works very well, from the top one can not tell the diff.
If you want stock i would say don't cut it. If you want somebody else to install a radiator they will surely screw up something else getting it in, since they have no concept of how much a PITA it is to do it correctly.
That is the way my 72 A/C 350 is. When I purchased it I thought it was stock because the cut was straight and had a piece of metal that was screwed in to hold it together.
Look...for those of you who do not have A/C and and auto tranny, don't pretend to know what you're talking about. The one-piece plastic [full-face] shroud is a real PITA to get out of there. It's almost impossible without breaking it to begin with...
I have a 77 with auto and A/C and never had the urge or need to cut it in order to get it out. All it takes is some disassembly and patience.
