Dome light problem
Old Apr 7, 2011 | 11:05 PM
Deviant80's Avatar
Deviant80
2nd Gear
Default Dome light problem
I just experienced this problem today, my dome light and the light near underneath my steering column stay on. I have played with the courtesy light twisting the **** and what not to try to shut it off but it will not turn off. It wasn't ever on before until out of the blue today. Does anyone have ideas on what this possibly could be?
Old Apr 7, 2011 | 11:07 PM
RIO68's Avatar
RIO68
I'd start at the jam switches????
Old Apr 7, 2011 | 11:14 PM
Deviant80's Avatar
Deviant80
2nd Gear
Where are those located?
Old Apr 7, 2011 | 11:55 PM
7T1vette's Avatar
7T1vette
I believe your car has a delay timer module on the interior lights. Chances are it has "thrown craps" and is stuck in the ON position. You will need to disconnect it to keep from running the battery down...and replace it so that it can work properly.
Old Apr 8, 2011 | 12:09 AM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Yep, delay....
Contact Willcox. They offer a replacement circuit board that goes inside the orange box.
Old Apr 8, 2011 | 08:59 AM
golfradict's Avatar
golfradict
Originally Posted by KapsSA
Yep, delay....
The little orange box is located just to the right side of the glove box, when you remove the tray inside you will see it, a mechanic told me he has had to replace them because of lights staying on and also lights that won't come on at all.
Old Apr 8, 2011 | 11:32 AM
Hardway's Avatar
Hardway
If you want to ditch the timer all together and save yourself some $$$ you can unplug the timer box, on the harness that was plugged in to it, take a piece of wire and jump the two white wires on each end of the connector. This is what I did on my '81 and it works perfectly. Now your dome lights will turn on and immediately turn off when you open and close the door. I never liked the dimming feature on dome lights because I am always afraid it will stay on.
Old Apr 8, 2011 | 11:35 AM
7T1vette's Avatar
7T1vette
Sounds like a plan...
Old Apr 8, 2011 | 02:33 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
on older cars like ours, this is a very helpful suggestion. it just eliminated one more potential problem area (unless you replace the parts with new to make them more dependable). personally, i would want the car to function (if at all possible) the way it came from the factory, but i can appreciate the apprehension of potential gremlins that seem to haunt older cars that don't see regular use.
Old Apr 8, 2011 | 04:56 PM
golfradict's Avatar
golfradict
Think I will do this also, I'm into the worry free idea.
Old Apr 8, 2011 | 07:24 PM
batmedic's Avatar
batmedic
One other thing to check is the ground. I have been told that the ground controls the timing circuit. Mine has had similar issues. When a find a better ground it works again. Food for thought.
Old Apr 19, 2014 | 11:35 PM
corvettesummer79's Avatar
corvettesummer79
I jumped mine but now I cant turn the dome light on from the headlamp switch. It just comes on and off when you open and shut the doors. anybody know why?
To Dome light problem
