1981 differential question
Old Apr 8, 2011 | 10:30 AM
81coupeowner's Avatar
81coupeowner
Default 1981 differential question
Im about to rebuild my rearend and would like to put in a set of 3:54 or 3:73 gears. The question is do I need to replace the carrier unit as well or will it work with the new gears?
Old Apr 8, 2011 | 12:08 PM
Rebelrob's Avatar
Rebelrob
Do you have the dana aluminum rearend? You need to buy your ring/pinion set based on the the type of differential you have.
Old Apr 8, 2011 | 12:40 PM
81coupeowner
yes rebelrob it is the aluminum rear end with 2:76 gears right now i want to upgrde to 3:54 or 3:73. I've read several posts about it but noone mentions the carrier unit in any of them.
Old Apr 8, 2011 | 08:19 PM
spedaleden's Avatar
spedaleden
You do not have to change the carrier unless something is wrong with it. You just need new ring and pinion and differential rebuilding kit. No thrust washer on 80 - 82 diffs
I went with 3.55 and love it also have 5 speed manual trans
Old Apr 9, 2011 | 09:04 AM
81coupeowner
Thank you Spedaleden that is very helpful.
Old Apr 9, 2011 | 09:21 AM
spedaleden's Avatar
spedaleden
Stay away from Richmond Gear, used to be great but quality is not what it used to be. I used Richmond first time as gears worn in noise got worse. I think my next set was motive which have been fine so far, for 10,000 miles
To 1981 differential question
