Steering Column Paint - HELP !
Old Apr 8, 2011 | 02:14 PM
MrJlr's Avatar
MrJlr
Default Steering Column Paint - HELP !
Flat, Semi-Gloss or Gloss ?
Can somebody "steer" me in the right direction ???
Thanks in advance !!!
Old Apr 8, 2011 | 02:49 PM
69FASTFUN's Avatar
69FASTFUN
I painted mine Krylon semi flat black. If yours is a different color I would go semi gloss
Old Apr 8, 2011 | 02:59 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Semi flat to match the interior color.
Old Apr 8, 2011 | 03:35 PM
BBCorv70's Avatar
BBCorv70
Is semi flat the same as satin?
I've had good results with Satin on the center gauge cluster and console shifter plate.
Definitely not gloss or flat.
Old Apr 8, 2011 | 03:38 PM
Roco71's Avatar
Roco71
I used satin looks great
Old Apr 8, 2011 | 04:28 PM
MrJlr's Avatar
MrJlr
Thanks !
Old Apr 8, 2011 | 04:46 PM
Alan 71's Avatar
Alan 71
Hi jlr,
Even with a spray can, I've found you can vary the amount of gloss a bit by spraying the paint a little 'wetter' or 'drier' to get the look you're after.
Good Luck!
Regards,
Alan
Old Apr 9, 2011 | 10:25 AM
thegazman's Avatar
thegazman
Default thegazman
I painted mine with the same paint as the interior trim I bought from corvette central (79 oyster). I primed it, painted it, then sprayed it with the low luster clear coat.
To Steering Column Paint - HELP !
