DIY - Corvette Top Installation
Old Apr 10, 2011 | 02:12 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default DIY - Corvette Top Installation
Thought I would make a thread on how to install your own C3 convertible top to help the budget minded owners and it seems like a challenge. The thread is going to take a few weeks to complete, since I travel for work and also have to many other hobbies.
Lets start with what you need. Attached is a pic of the basics you will need.
Other items will include:
Wire wheels and bushes to knock off the rust.
Sand Paper.
Rust converter.
Masking supplies.
I purchased all the random bolts and springs from different corvette parts houses.
Step #1
Remove the old top. Pretty simple, just pick a spot and start pulling weather stripping off. The hardest will be around the side windows. Lots of tiny bolts. Please note "Save all the old parts for use later". That includes the top and pads.
Also take lots of pics.
Old Apr 10, 2011 | 02:20 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Step #2
Once you get the frame clear of staples and pad, start wire brushing and stripping with sanding disk. I like the ones that screw on to the 90 degree air grinder. Since this is a budget job I will not be replacing the tach strip, mine looked good and there was no reason to remove it. Same with the felt.
Survey the damage.
Looks like the rear bow is going to need some welding.
Also you will probably have some rust under the front header. You will need to decide how far you want to go with those repairs. I had a few small holes that will be covered with weatherstripping, so I will just fill them and cover.
Step #3
Rust treatment. Pretty simple just spray and wait overnight. I like this stuff, but it does not like plastic so tape it off.
Old Apr 10, 2011 | 02:25 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Step #4
Finish coat. I went with the John Deere paint as suggested. It's ok, but coverage is sub-par for my standards. I will try a scratch test after it cures for a few days. If it strong enough I will live with it. Also the finish is not as glossy as I would have preferred.
One more pic before finish coat.
Old Apr 10, 2011 | 02:29 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Should read DIY, hopefully the mods can fix that.
Old Apr 10, 2011 | 02:43 PM
blueray72's Avatar
blueray72
You can edit the thread titles for new threads in the edit settings under "advance settings"
Old Apr 10, 2011 | 03:12 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Thanks, got it.
Old Apr 10, 2011 | 03:35 PM
Gordonm's Avatar
Gordonm
This is perfect. You are a couple of weeks ahead of me. Mine should be back from the paint shop in about 2 weeks and the top is my next project. I have all the stuff needed just need to get the car back and some time to do it. This will certainly help out.
Old Apr 27, 2011 | 11:03 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Before pics: A couple nights in front of the TV and the bright work is polished. Also discovered the 1968 has it's on special screws that hold the front pins in.
Had the crack TIG welded. I hated to sand down that pretty bead.
At this point you can install the two front peices for weather stripping. Do not install the front screw, you will install it almost last.
Not sure why this tab was not pre-bent, it would help with orientation. Luckly I saved my old springs.
Old Apr 27, 2011 | 11:05 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Frame is complete. Now the fun begins.
Old Apr 27, 2011 | 11:31 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Great post! Keep it coming
Old Apr 28, 2011 | 06:25 AM
Jethrotracey's Avatar
Jethrotracey
Doing an X O Lent job buddykeep us posted on the progress. P.S. did you end up getting a vinyle top or cloth top ?
Old Apr 28, 2011 | 07:31 AM
ikwhite's Avatar
ikwhite
Thanks for taking the time to post your DIY top install, as at sometime I am going to have to tackle this too and should come in handy.
ikwhite
Old Apr 28, 2011 | 08:34 AM
pws69's Avatar
pws69
A suggestion:
After I cleaned up the latches, I dipped the lever parts in black "PlastiDip" - used for tool handles. Came out real nice - looks like it should be that way!
One of the trickiest parts to me was getting the rear tack strip in the correct place on the top. The problem is that you staple the pads on before you get the top in place - but once the pads are stapled and you get the top in place, it can be a real PITA to move the tack strip. Tough to explain, but I just wanted to alert you to it so when you get to that part, you can slow down and see what's going on between the different pieces.
Old Apr 28, 2011 | 02:09 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
That and those rear straps. I probably moved them three times trying to get them somewhat vertical. I still might move them again.
Old Apr 28, 2011 | 10:33 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
WARNING - YOUR TOP MIGHT NOT BE THE SAME SIZE. MEASUREMENTS MAY BE DIFFERENT ON YOUR CORVETTE. USING THESE MEASUREMENTS MIGHT RESULT IN THE PURCHASE OF NEW PADS AND STRAPS.
I bought the rear of the pad down to 7".
Straps were stapled at approx. 12".
Second bow is stapled at 9" from rear bow.
First bow is stapled at 12" from second bow.
Old Apr 28, 2011 | 10:39 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Front of top to rear bow is 33 1/2". This is with the top not latched and the rear bow at the first click.
Foam cut, marked, and glued in with contact cement.
Front is taped. Need to check and see if I need to staple it also.
Rear pad is stapled and taped.
Old Apr 28, 2011 | 10:56 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Looks close to me. It's whatever Al Knoch sells. Really not sure what the difference is.
To DIY - Corvette Top Installation
Old May 1, 2011 | 12:45 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Bump for adding new pics.
Old May 1, 2011 | 06:33 PM
milo30's Avatar
milo30
Great info. I'll be doing this soon. I am in the DFW area so may have to give you a shout.
Old May 1, 2011 | 07:40 PM
Gordonm's Avatar
Gordonm
Good info. I'll be referencing this often when I do mine next. The tops are a StayFast top from Al Knoch. Mine is the same one.
