4.11s in a 79 with a th350 is it practical?
Everything comes back to how much are you willing to spend and change.
4.11s can make for great acceleration if other things are changed........but would be even less than USELESS in a bone stock '79.
The L82 and base motor are both GARBAGE with a pathetic cam profile tuned more for meeting emissions standards than they are for power or top end. Then there is that 1:1 final gear in the transmission. 4.11s in a stock car would just BLOW big big time.
On the flip side?
If you could see spending a few more dollars on a decent engine with some actual power and it makes it's power where it's supposed to for performance you could build a better drag strip car with 4,11s.
Spend a little more still and with an Overdrive transmission you could keep your highway cruising speed sanity.
On the flip side?
"A guy" was wrong. Where in that simple math is consideration for tire size?
Well I honestly do not care about gas mileage I drive less then 1000 miles per year with the car... Its got a 383 stroker in it now and the 3.08s or what ever is in there is just too damn weak. However most of the roads around here are country roads (im in the Poconos) so im usually cruising around 60. Not being able to get on the highway kind of stinks but its not the end of the world either. I think 3.73s would be a better choice but the price is right on the 4.11 setup... Guess I gotta think about it for a day or so heh
Does anyone have any idea what kind of rpms id be turning in my 79 with a th350 if I were to drop in a 4.11 rear? I had planned to go for 3.73s but the opportunity to get a nice 4.11 setup has presented its self and I am wondering if it would still be street able with the 3 speed auto.
I ran 3.70 gears in my 80 for twenty years. Initially with the 350 and a fairly smallish cam I averaged 17 mpg commuting 400 miles a week to work. Keep the speeds around 60 mph, you'll see 3000 on the tach. Then it was my daily driver. Over time I got the bug, and put in a 406. bigger cam,....blew three trannies sorting things out, and after tuning to perfection now get about 12 mpg, but sometimes see 7000 on the tach.
How's that for practical?
Right now I'm in the process of swapping in 4.11 gears, along with a ton more mods. The car hardly gets driven anymore, just a toy,....so practical? Who cares.
I have 4.1:1 RP. It is a 383 and a 4 speed Muncie. For my use it is fine. If it were a daily driver, it would be terrible. Where I drive, one needs to be able to cruise around 90 mph.
At those speeds, even a 3.36:1 would be uncomfortable.
