Safety Question/Concern
My concern is that the force I am having to use to loosen bolts and even some hammering may be needed, is shaking the car more and more. Also as I remove stuff it is lighter and lighter.
What precautions should I be thinking about to possibly make it sturdier. I want the car to stay up at the 30" height I have it at right now so I can get under it easier and not have to do a huge amount of bending when I start the body work.
Once the front suspension is off, will the car bee too light to keep up at that height safely? additional 12 ton stands? Any other ways to keep it stable?
Maybe I am just being a little to cautious, but my son is out there with me most days and I dont want him or I to get hurt.
Have you got a copy of the AIM (assembly instruction manual) for your year? It will show the 4 lift or jack points on the frame. Your rear ones look correctly positioned.
Is the motor in the first picture, out of the car? I found that relieving the weight from the rear axle wanted to tip the nose down in mine as the motor was still in it. I stabilized by adding a 5th support point under the front crossmember.
Not as big a concern if the engine bay is empty.
My only suggestion is to relocate the 2 forward jack stands a little farther outboard and rearward on the frame than where they appear to be in the photo. The AIM will explain it; the Owners Manual may also have it described. You can always use the "search" feature here to get the straight skinny too.
Once the jackstands are in the recommended location, they will support the car fine.
When I am working under my car I use more jacks than I think is needed, and keep a hydraulic jack in place as extra insurance. In your case you have your car lifted past the hydraulic jack area, so you may want to put extra jacks in at other load points such as the front crossmember as insurance.
kdf
I did try the 2 stands futher back toward the doors but it had a slight rock in the car at that point. maybe the shape of the frame or the grarage floor itself (or both) added to that. where they are now did not rock at all.
Maybe the shifting of the weight front to back is really what I am noticing. when I was removing the passenger T/A it seemed to shift a little when I had to put some pressure on the leef spring bolts.
I think I will add 2 more jack stands to the front tips again. The side to side seems fine. I will just checking it and adjusting it if need be.
Any time you use 4, or more support points, especially with metal-to-metal contact, you will always have at least one point that isn't supporting it's share of weight. You coupl have the straightest frame in the world, and it still will have a "soft point". Mabe an uneven floor, differences in the jack stands, etc.
ALWAYS USE RESILIENT PADS! Even if you have to chop up an old tire,
I most likely am going to go get 2 more stands, and something to prevent prevent the slippage.
May not be an issue, but a piece of mind is a very good thing
I was taught basic mechanics by a former WW2 tank instructor. After we jacked up a car, he would come along and do his best to knock loose. If it moved at all, it failed.
kdf[/QUOTE]
I always use 8 jacks, two on each corner of the frame per AIM, and another one under the front cross member and 10th one in the back. Likely overkill I know, but I like to have the Corvette higher to get access easier.
Speaking of soft corners with only 4 jacks, when I bought my 76, the seller per my request had jacked it up in his driveway for me to look over underneath. While crawling around checking out the underside, I accidently bumped one of the 4 jacks out as it was just sitting there with no weight on it. This freaked me and the seller out a bit
, but I bought the car anyway. Maybe this is why I like lots of jacks?
...does it make any sense to do something like that(tho stronger?) for the whole car?
I wouldn't mind to be able to move my project car around alittle, and have it off its wheels
