So how fast
Old Apr 21, 2011 | 08:06 AM
sbranscum's Avatar
sbranscum
Default So how fast
Curious, what was/is the top speed of say a 68/69, BB out of the factory back in the day?
Old Apr 21, 2011 | 09:08 AM
joewill's Avatar
joewill
depends on the rear end ratio
a 4.11 will probably top out at about 110
a 3.08 will probably do about 145
if someone is crazy enough to take it that fast...
Old Apr 21, 2011 | 10:03 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Some of the old Road and Track articles claim 150 in the coupes with a big block. My 68 427/390 coupe has a factory 3:08 rear and it gets into triple digits very easily. Haven't had it any where near what I think it's capable of but it's far from running out of breath at 120.
Old Apr 21, 2011 | 11:33 AM
7T1vette's Avatar
7T1vette
It's pretty simple to "do the math" to determine maximum possible vehicle speed. You need to know tire diameter (or rolling radius), rear axle ratio, and engine 'red line' [assuming it has enough horsepower to get to redline at max speed].
Base SB will probably do around 120 or so. BB should do 130 or more. Big BB in a coupe could reach 150.
Old Apr 21, 2011 | 11:53 AM
MelWff's Avatar
MelWff
69 L88 http://www.corvetteactioncenter.com/...8/l88perf.html
small block and big block under ponycars
http://www.ls1tech.com/forums/automo...or-1969-a.html
Old Apr 21, 2011 | 11:55 AM
RagTop69's Avatar
RagTop69
My speedo says 160. I'll let you know when I get back......
Just kidding. I know mine will slice through 100 mph without much fuss. It's too old and too valuable to risk something stupid like a high speed pass. Besides, the CHP takes a dim view of these things. Mine has 3.36 gears and an M21 4 speed.
I just checked out that Car Life matrix in the post above. I think I would have to call B.S. on that 13.41 e.t. for a 427 with 3.55 gears unless it was the 435 hp version. My L36 has 3.36 gears and I know it's nowhere near as fast as my LS1 Z28. That car turned a best of 13.44 @ 107.43 mph with 35K miles on the clock and a set of 2.73 gears.
Old Apr 21, 2011 | 12:01 PM
joewill's Avatar
joewill
a 3.08 does about 2200 rpm at 60 mph = about 37 RPM per 1 mph.
divide a redline of 5600 rpm by 37 = about 151 MPH..
presuming of course you have the horsepower and torque to pull to the redline at high speed. it takes alot of horsepower/torque to run a car at 151 MPH
I think you will run out of torque and be past your horsepower peak to a fair degree below your redline.. limiting your top speed.
the 435 may get you there since it has higher torque and horsepower peaks at higher rpm.
hitting redline going thru the gears is entirely different than running at redline for a couple of minutes trying to top end a car.. I am not that brave and my engine is too valuable..
Don't forget clutch or torque converter slippage also..
also doing this on improperly rated or old tires may win you a darwin award.
Old Apr 21, 2011 | 09:03 PM
shrekviper's Avatar
shrekviper
Sweet, with my RS600 I'll be doing 221mph at my redline. Now if I could just squeeze that power out of my BB.
The problem is if you go that fast nobody will be able to see you cruise by.
Old Apr 21, 2011 | 09:23 PM
Gordonm's Avatar
Gordonm
Can I play. My motor will turn 7000 rpm. With my gearing and T56 trans I can do 258 mph.
Seriously a lot depends on which motor you are talking about, what gearing is in the car. To vague a question. Like how high is high. Way up there.
Old Apr 21, 2011 | 09:29 PM
Birdman's Avatar
Birdman
Mine's been going -1mph lately..
Old Apr 21, 2011 | 09:41 PM
3JsVette's Avatar
3JsVette
Not really an "out of the factory" 68/69 BB Corvette but........from Motor Trend 5/69 Duntov's "mule" ZL1 with a 3:70 rear did 145 MPH @ 6500RPMs.
Old Apr 21, 2011 | 09:44 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
I chickened out @ 120 mph with what felt / appeared to be a lot more room to go ........ BB 427 / 4spd / trips / 3:08's
Old Apr 22, 2011 | 07:57 PM
sbranscum's Avatar
sbranscum
Wow, does it matter if it is auto or manual?
Old Apr 22, 2011 | 10:12 PM
PRNDL's Avatar
PRNDL
You guys forgot wind resistance. Even turning redline, "doing the math" won't give you the real top speed; your car will "hit the wall" much lower. Not to mention I have heard these cars get very "light" at speeds far below theoretical maximum.
Old Apr 23, 2011 | 10:12 AM
Lemans Blue 69's Avatar
Lemans Blue 69
ZL1 doing 145 at 6500 w/3:70's sounds right. My 69 w/3:70's topped out at about 140 at 6000 rpm. That was back in 1970 when I was younger and fearless.
To So how fast
