'78 Restoration Project
As you can tell from the photos, it needs some work to get back to its glory days but that is what I was looking for. Now I have never tackled a project like this before, just done a few engine swaps and other shade tree stuff. However, I have been inspired by some of the threads here on the CF by folks who are no more experienced than I am tackling similar projects.
I will be searching past threads and posting frequently seeking the sage advice of the many knowledgable folks here as I get into this project. Any of you Dallas area C3 guys who want to stop buy and offer advice PM me, I can offer cold beverages and Corvette conversation to anyone willing to help keep me pointed in the right direction. I hope to do a frame off on the car and I am thinking of pulling the engine and tranny as a first step. Anyone with a different suggestion as to how to start, please chime in.
Forrest
A new CORVETTE project!!!!
Well done!!!!
I may be able to help with some suggestions about the way to get started, documenting what you have, and controlling the thousands of parts you'll need to restore and then find again someday.
But.... if the car is driveable in a SAFE manner; why don't you drive it a bit to get to know it, and to get some idea of what needs the most work. Then start in on it.
Regards,
Alan
Well done!!!!
Regards,
Alan
Bill
What is you time line to finish? I have a friend doing the same thing to a 73 along with me here in my shop. I'm going to document and photo my entire ordeal.
I have an automotive machine shop, so I've begun the engine already. I have a Dart little M 400 block with billit 4 bolt caps. Crower rods and JE pistons. A set of Canfield aluminum heads and am going to order a mild solid roller cam.
We'll have to stay intouch as this goes along. I suspect with paint I'll shoot for next spring.
Bill
Plastic baggies.
That's right.
Every time you pull bolts off something, drop it in a sandwich bag and LABEL it. Store all the bolts in tupperware or whatever sturdy containers. It makes things a complete breeze when reassembling the car. I saved myself countless hours by doing this.
Also, when possible, try to put bolts and nuts back on the part you took it off. Like the alternator adjusting bolt, just stick it back in it's threaded hole. Or if you take off the brake master cylinder, put the 2 nuts back on the vacuum booster. Makes your life even easier later.
Personally I wouldn't recommend a frame-off to start. You will end up feeling overwhelmed at some point and get very frustrted. I have done almost a complete restoration of my own 78 in small sections. I would only just now consider doing a frame off after gaining the knowledge of the cars I have now.
Your biggest hurdle is documentation is poor, scarce, and often incorrect. Even the Assembly Manuals often depict parts that were never used or were changed during production. Unless you've put one of these together once before, you'll end up spending 50% of your restoration time here on the forum searching why a wire is blue when the manual says it should be yellow and various little annoyances of the such.
Take it slow with small projects to start. You'll be much happier.
You may also share with us your restoration plans whether its to rebuild
1. to original factory specifications for NCRS specifications
2. a nice driver but retain originality
3. Over the top, restoration with "go fast" parts
It helps to know in advance so we can offer advice based on your plans rather than what we like.
Regards,
Alan
PS: Congratulations! You'll enjoy the project.
Trust me. I know. I'm suffering now putting the dash and console in my 78 back together right now. I was sure I'd remember it. WRONG!
Geno
Bill
FORREST!!!
I SWEARRRR I saw your driving your car down college/ohio around last weekend. You didnt see me in my green 75 but I waved. Il pm you with my number so we can set up a good time to meet. I also have three C3s at my house. I live off of hillcrest and rolator.
