date casting code question.
Old May 1, 2011 | 10:23 AM
1lkydog's Avatar
1lkydog
Default date casting code question.
date casting code on this 454 motor reads A28-71. My guess is Jan. 28 71 but everthing I have read only has one number for the year. What am I missing. thanks for any help. gary
Old May 1, 2011 | 04:47 PM
vettebuyer6369's Avatar
vettebuyer6369
Usually a 2 digit year format means its not a Corvette engine.
Old May 1, 2011 | 04:56 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
not for Tonawanda cast engines. only Flint used the single digit date format. and all BB came from Tonawanda
Old May 1, 2011 | 04:58 PM
BBCorv70's Avatar
BBCorv70
Is this true of later big blocks? This article says a two digit year indicates the block came from the Tonawanda plant. I'm pretty sure the 454's were built there. Was it Flint that was one digit, small block?
http://www.corvetteblogger.com/2007/...engine-stamps/
Old May 1, 2011 | 06:30 PM
vettebuyer6369
Absolutely right... didnt even think BB. Thats what I get for posting on Sunday!
Old May 1, 2011 | 07:12 PM
1lkydog's Avatar
1lkydog
That would make sense. The front pad # is T 0215 cpj . The other block casting # is 3963512. If I have all of this right it should be a 1971-454 with 365 or 425 hp. I will have to see if it`s two or four bolt mains. Is this all correct for the # I have posted? Thanks for the input. Gary
Old May 1, 2011 | 07:44 PM
corvetteload's Avatar
corvetteload
I thought casting dates after 69 went to 2 digits for the year
Old May 1, 2011 | 08:21 PM
joewill's Avatar
joewill
yes, 69 and earlier were 1 digit years and 70 is a 2 digit year.. at least in the seventies..
the cpj code is for a 365 HP automatic, and is therefor a 2 bolt main engine, oval port heads. iron intake rochester quadrajet
amd yes A28 is january 28
Old May 2, 2011 | 09:00 AM
corvetteload
So this statement is wrong, just want people to not confuse things here, this is how misinformation gets started
Old May 2, 2011 | 10:12 AM
Mike Ward's Avatar
Mike Ward
No, it's correct- if the subject is small block engines. Flint supplied 99.9% the small block engine cases for Corvette. One simple way of telling the difference between a Tonawanda small block and Flint small block is a single digit or double digit for the year in a casting date. Then there's McKinnon Industry cases but that's another kettle of fish.
Old May 2, 2011 | 12:05 PM
joewill's Avatar
joewill
chevy made hundreds of thousands of small blocks and big blocks in any particular year, only a small percentage of them were installed in a corvette..
To date casting code question.
