#4 body bracket
Old May 1, 2011 | 04:44 PM
SMD 1976's Avatar
SMD 1976
Default #4 body bracket
both of the #4 mount holes are bad. i measured #1 mount hole 1 3/16" so is the #4 the same, also how far from the frame rail is the center of the mount hole. just going to cut out top plate on mount and fab new top plate and weld in using .125" steel. then off to blast and powdercoat. tks steve
Old May 1, 2011 | 07:46 PM
mikep3's Avatar
mikep3
http://www.bairs.com/search.asp
Try one of the Corvette Parts Vendors.
Bairs had replacement tabs for body mounts.
