Compression testing
Old May 4, 2011 | 08:45 PM
petdoc's Avatar
petdoc
Default Compression testing
My 70 L-46 is supposed to have 11:1 compression and 350hp. It just doesn't seem to have much "get up and go" to me. Granted my last vette was an LT-4 car and I am used to power, this one just seems anemic. I have pressure guages, but am ignorant on how to use them. Is there previous thread related to compression testing? Or can someone briefly explain to me how to test. This motor has been rebuilt, so I am wondering if it may have been rebuilt with the wrong parts. Also any recommendations on other likely culprits to check would really be appreciated. This car seems very sluggish..... As always, Thanks in advance, Lee
Old May 4, 2011 | 09:10 PM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
My old L-79 327 with an L-46 cam was a screamer. Very responsive. Same advertised 11:1, 2.02 heads, basically stock motor except for ehheaders.
It had about 190-200 pounds of cranking compression.
Doug
Old May 4, 2011 | 09:16 PM
Gordonm's Avatar
Gordonm
What cam did they put in it. What is the timing set at and how is the adbance curve. Is the carb adjusted properly. The L46 should be a very responsive motor.
Old May 4, 2011 | 11:41 PM
petdoc's Avatar
petdoc
I have no clue what cam/pistons etc is in it. It was "rebuilt" in the early 90's (15,000 miles ago).... It has a Holley on it instead of the QJ. I really don't know where to start. I figured checking the compression would be a good start.... yes/no???
Old May 4, 2011 | 11:52 PM
7T1vette's Avatar
7T1vette
No offense meant...but, if you don't know where to start, you shouldn't be "doctoring" your own engine. And I doubt that you are going to learn enough from asking questions on this Forum to be able to do a good job at 'fixing' it--if it even needs fixing. Your first order of business is to identify a competent, affordable mechanic who can assess the condition of your engine and let him/her clear things up.
Contact a local Corvette club or vintage car club to see who they might recommend. Stay with a private shop...not a chain store.
Old May 5, 2011 | 02:07 AM
Peterbuilt's Avatar
Peterbuilt
Originally Posted by petdoc
I have no clue
Many others had no clue either but there are plenty of very helpful and knowledgeable people on the forum so ask away. If you don't mind grease under your nails and have some tools then you can do it! A 70 Service Manual and an AIM would help a lot.
Just because you have a compression tester doesn't mean that should be the first test.
You have points? Check or replace them,
Buy a dwell meter-dwell should be 29-31 and remain steady as you increase RPM.
Get a Dial Back timing light-disconnect and plug the vacuum advance hose and post back the numbers at idle and increase the RPM slowly to about 3,000 and see how much mechanical advance you have.
Let enging idle and reconnect the vacuum advance hose-post how much timing increases or not.
Check or change the spark plugs and now you can do the compression test.
Leave the carb alone for now.
Old May 5, 2011 | 02:53 AM
STINGRAY1WORD's Avatar
STINGRAY1WORD
Don't forget to inspect your Dist. Cap for carbon tracking. That can creat power loss as well.
Old May 5, 2011 | 07:28 AM
petdoc's Avatar
petdoc
I've always been a bit of a grease monkey. I have torn down and re-assembled a couple of 350's in the past...it's just the fine tuning that stumps me. I have an old timing light, but prob need the newer Dial-Back version....and I'll pick up a dwell meter as well. I'll get going here asap and post results. Thanks a million! Lee
Old May 5, 2011 | 07:29 AM
petdoc's Avatar
petdoc
Thanks! Will do!
Old May 5, 2011 | 08:37 AM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Years ago I was told by the local vette guru the first thing he checks, when a customer complains about a lack of get-up-and-go on these cars, is the accelerator. Imagine that.
On the NCRS board a while back, somebody was trying to diagnose a lack of performance. I told him to first check and see if the throttle cable was opening the carb all the way. He did not, then followed the stream of advice from others and had the carb rebuilt...and just about everything else. Finally he noticed the accelerator pedal arm was bent, which is common after many years of mashing it to the floor. Simple fix just to straighten it out.
Old May 5, 2011 | 10:52 AM
7T1vette's Avatar
7T1vette
Lots of folks think that using their hand to actuate the throttle linkage on the carb is the same as depressing the accelerator. Not so! There is a pedal assembly, a cable, and some other hardware in the system before it gets to the carb linkage. And, if you can't verify that depressing the accel pedal [with your foot] will fully open the carb secondaries, you shouldn't even be thinking of working on the engine...yet.
Old May 5, 2011 | 11:11 AM
joewill's Avatar
joewill
It depends on your cam profile as to what compression you are getting, the later the intake valve closes, the less compression (at cranking speed) you are going to get.
listen to all the above advice, you need good ignition, good carb setup , good mechanical and vacumm advance, etc..
Old May 5, 2011 | 12:12 PM
Peterbuilt's Avatar
Peterbuilt
You and Faster Rat are 100% correct, many times just moving the floor mat is the FIX.
Old May 5, 2011 | 01:14 PM
petdoc's Avatar
petdoc
WOW....That just moved to the top of the list!!! Thanks....Lee
Old May 5, 2011 | 02:43 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
What have you done to the car? Have you checked the timing? Looked at the spark plugs? Checked the wires, cap and rotor for wear? I would start with those first and get more complex from there. Is the car still on a points distributor, hei, msd or other type? The carb could need some work on jetting. The valves may need adjusting if it is a solid lifter cam. There are a lot of simple issues it could be before I would go checking compression. That is just the quick stuff I can think of off the top of my head. Start looking there and give us a full run down and we can suggest more ideas from there.
Old May 5, 2011 | 03:56 PM
Kevins77's Avatar
Kevins77
I will say - My 383 Stroker doesnt feel 'all that powerful' in the low end on my car.. it REALLY wakes up in the mid-higher RPMS because of the cam profile and the gearing.
Feel is just too subjective. A torque monster can feel WAY more powerful than it is - instant torque just gives you that illusion. My car will pull like crazy, but it is from nearly 3000rpm - 6300rpm or so that it really FEELS like it has power. I know for a fact - I raced a buddy @ the strip last year who has an 85 4+3 lightly modded. His car makes ALL its power low - andif you ride with him to say 40mph, then ride with me to 40mph, you would SWEAR his car would stomp mine. Put them on the strip? I had a football field on him by the end of second.
Thats why the butt dyno is so unreliable for really gauging how fast a car is.
Old May 5, 2011 | 04:55 PM
joewill's Avatar
joewill
use a compression test to not check for total compression per cylinder, but use it to check for a difference in any particular cylinder. low compression on any one particular cylinder that is say less than 90% of the rest may point you to valve/ring/head gasket/ flat cam types of issues.
this is similar to a troubleshooting trick of pulling one plug wire and measuring rpm drop at idle.. each cylinder should show equal or real close to equal result.
To Compression testing
