Choke Light 1981
Old Dec 31, 2011 | 11:26 AM
Gears5's Avatar
Gears5
7th Gear
Default Choke Light
I have tried them all to this point. The last thing my dealer told me was to replace the element. I still need to find one when I take it out of storage
Old Dec 31, 2011 | 12:10 PM
C3-PO's Avatar
C3-PO
Default it's been a while ....
my problem just started a couple of weeks ago. i'll keep on it. if i find a solution, i will post.
Uugghhh ... now the windows are stuck up and won't work either. WTF! is a goin' on?
Old Jan 8, 2012 | 05:58 PM
C3-PO's Avatar
C3-PO
Default if you don't think ....
i found a nice fix ... when messing with the 'harmonica connector" looking for connections, i dropped the steering column and pulled the ignition connectors out half way and all my problems started .... dead power windows, choke light on, guages went crazy,.... etc. tracking this now for two weeks, i decided to look at the 'harmonica connector" again and DOH!, i found both connectors pulled out loose. plugged them back in and everything works great! give it a try, takes only about 10 mins. good luck!
URL=http://imageshack.us/photo/my-images/713/ccf0108201200000.jpg/][/URL]
Uploaded with ImageShack.us
P.S. for those who don't beleive, my car started ran just fine with the loose plug.
Old Aug 4, 2013 | 05:25 PM
John Ulrich's Avatar
John Ulrich
I finally replaced the relay which is located under the console in front of the shifter. Remove the two screws holding the carpeted panel on the drivers side of the console and let it swing down on the rear screw.
The relay is sitting right there. I went on a couple hour drive and it never came on.
I purchased mine from Rock Auto for 1/2 the price of Corvette vendors.
It replaced a 14039662. Their part number is STD RY-144 $16.04 with shipping.
Old Jul 25, 2022 | 06:53 AM
rive872's Avatar
rive872
Originally Posted by Mark Hawkins
Well it took me about 30 minutes to get the fuse out and the fuse was the problem, it had blown. I installed a new 20 amp fuse and fixed the problem. Thanks guys.
Hi, where is this fuse located?
Old Jul 25, 2022 | 09:38 AM
Bikespace's Avatar
Bikespace
Deep under the dash on the drivers side, behind the clutch pedal.
Here's my 80, which had wacky symptoms until I replaced the choke fuse. I think it is the top-right 20 amp fuse, but it should say on the panel, just not from this angle.
Old Nov 8, 2022 | 08:03 AM
johnleo's Avatar
johnleo
2nd Gear
I had the choke light on and the engine would not drop back from 1,800 RPM to idle. Ultimately I had a blown choke fuse and a bad choke relay. The fuse is a pain at the top right of the fuse assembly. The choke relay for my '81 Corvette has a normally closed contact. After buying a "direct replacement" on line, I off out most on line relays have open contacts, not closed. I found the NC relay #25773 on line at Top Flight Automotive for $32.
Old Feb 27, 2023 | 05:45 PM
Arizona C3's Avatar
Arizona C3
Default Chock light on a 1982
So I just had my instrument cluster apart and noticed there is a window in the tach for the choke light and a lens with the word “CHOKE” on it. Obviously the 82 is fuel injected so it doesn’t have a choke. It this just a leftover from 82? Can I remove the bulb holder and use it to replace one that is bad on the cluster without causing a problem?
Old Mar 1, 2023 | 12:06 PM
vettebuyer6369's Avatar
vettebuyer6369
If you have a new question about a different year car, please ask it in a new thread rather than tacking it onto a thread started 12 years ago.
