Choke Light 1981
Old May 8, 2011 | 02:17 PM
Gears5's Avatar
Gears5
7th Gear
Default Choke Light 1981
My choke light stays on. What can I do or where do I look???
Thank You
Old May 8, 2011 | 03:17 PM
Gears5's Avatar
Gears5
7th Gear
Default Choke Light
I think I found the relay, 2 brown, 1 blue, 1 green white
If I unplug this relay the CHOKE LIGHT stayes on!
Plug it back in
If I Unplug the blue wire at the choke heater unit on the carborator it self the light goes OUT.
I am lost!!!!!
What to do?????????
Old May 8, 2011 | 05:29 PM
c31980's Avatar
c31980
on my 80 CHOKE LIGHT comes on with ign ,, goes of after engine start
Old May 9, 2011 | 08:43 PM
Slotehog's Avatar
Slotehog
Do you notice a difference in the idle?
Check the Gauges fuse....I don't know much but when I took out the Gauges fuse to track down an ignition problem the Choke Light stayed on.
Good luck.
Andy
Old May 9, 2011 | 08:51 PM
Gears5's Avatar
Gears5
7th Gear
Gauge fuss is good and they all work, I also have power to the choke on the carb
Old May 9, 2011 | 09:20 PM
81pilot's Avatar
81pilot
Thank You
Mine did that when my alternator was going bad.
Old Dec 13, 2011 | 01:32 PM
Mark Hawkins's Avatar
Mark Hawkins
Thank You
Hey Gears5, did you even figure out what the problem was?
Mark
Old Dec 13, 2011 | 01:41 PM
Mark Hawkins
Good luck.
Andy
Hey Andy,
Going through posts to gets some idea's on what my problem may be and I ran across this post of yours. I have an 81. When I got the car, the electric choke was not connected. Someone had cut the pigtail off; all I had was a green wire. I could not find a pigtail to fit. To make a long story short, I got the electric coil & pigtail from Cliffs. When I connect the pigtail, my Choke Light stays on and I get a rough Idle. Your Rough Idle caught my attention. Why would I get a rough idle? The butterfly on the carb never changed positions when I plugged into the electric choke. I'm going to go and look to see if I have a bad fuse. Thanks Andy.
Mark
Old Dec 13, 2011 | 01:49 PM
qwank's Avatar
qwank
I don't have my service manual with me at work but I think I remember seeing the wiring diagram and the choke light circuit goes through the oil pressure switch I believe?
It's a simple circuit if someone can find a wiring diagram and post it up here, it shouldn't be hard to find out where to look for the problem. I just don't remember off the top of my head.
Old Dec 13, 2011 | 04:33 PM
SIXFOOTER's Avatar
SIXFOOTER
Check the choke fuse. If it opens up it dropps out the choke relay and the choke light gets a ground through the choke coil.
Old Dec 13, 2011 | 07:34 PM
Mark Hawkins
Thanks SixFooter, how in the world can I get the 20amp fuse out to check it? It is way up at the top and I can seem to get a hold of it to pull it out. Am I missing a trick here?
Old Dec 13, 2011 | 07:36 PM
Mark Hawkins
Thanks Qwank, I just asked SixFooter if he has a trick on getting the Choke fuse out in order to check it. I thought that would have been my eaisest thing to check. Thanks.
Old Dec 13, 2011 | 08:55 PM
qwank's Avatar
qwank
According to my service manual, that's not the correct wiring diagram for an '81. I'll take a pic and get it up here.
Edit: oops I was wrong. I was looking at the actual choke heater circuit, not the circuit for the light.
It says to check the fuse as already stated. If the fuse is good, check for voltage at the choke heater connector in cicuit 250 (brn wire)
It could also mean there no power at the actual choke heater.
Old Dec 14, 2011 | 07:24 AM
spikebot 81's Avatar
spikebot 81
Same here. Dim choke light while the car was running. Found the diodes in the alternator where bad. New altn. Choke system works correct now.
Old Dec 14, 2011 | 08:47 AM
81pilot's Avatar
81pilot
I third that motion, I replaced my Alternator and she cleared right up.
Old Dec 14, 2011 | 11:15 AM
SIXFOOTER's Avatar
SIXFOOTER
I use a scribe/probe with a bent tip to get fuses out.
Also , yes the diodes in the alternator can cause the choke light to stay on. With everything normal and the engine running you have 12v applied to both sides of the choke relay coil, effectively disabling it, the same on the chooke light. If the fuse opens up, you lose voltage on one side of the relay coil and the relay opens and the choke circuit becomes the ground side for the light. Its kind of a left handed way to do things, but it works.
Old Dec 14, 2011 | 08:54 PM
Gears5's Avatar
Gears5
7th Gear
I have checked the choke fuse and it's good. I also checked that there is 12 volts to the choke element. Heater never heats up. I think the choke heater on the carb is the problem
To Choke Light 1981
Old Dec 16, 2011 | 08:28 AM
Mark Hawkins
Well it took me about 30 minutes to get the fuse out and the fuse was the problem, it had blown. I installed a new 20 amp fuse and fixed the problem. Thanks guys.
Old Dec 16, 2011 | 09:07 AM
John Ulrich's Avatar
John Ulrich
Damm, I'll have to look into that next spring. My charging light is also dimly lighting so the alternator has been suspected for that light also. The choke light has been flicking on and off for years now!
Thanks!!!!
Old Dec 30, 2011 | 03:32 PM
C3-PO's Avatar
C3-PO
i too have the same problem ... light won't go out.
choke relay ... okay (even bought new and returned)
fuses okay ... i use a fuse clip (have had it for years)
cleaned altenator ... no change (even bought new, installed and put the old one back in and returned)
repaired charging connector ... had to resolder blade connectors, both broken and greased up.
choke works, stalls engine when i push close.
any other clues? thanks. this forums will always rock!
