I think I have a problem
Old May 11, 2011 | 10:09 PM
72 bucket of parts's Avatar
72 bucket of parts
Default I think I have a problem
Painted my Jams then put the dorr hinges together. Then I put the doors on so I could get started block sanding. After I got the doors on and the back gap looked pretty good,,,,,, I looked at the front one.
I am guessing I have to cut the front clip off and put it back on so everything lines up. Any thoughts?
Old May 12, 2011 | 01:39 AM
avner's Avatar
avner
Is the car stand on the wheels or blocks?
When you check the gaps the car must stand on the wheels on level surface.
Avner
Old May 12, 2011 | 07:47 AM
72 bucket of parts
It's on the wheels. I can't even take it lose from the radiator sadle and get it tighter. The body sat on a stand for years without the front end suppoeted. I am guessing this had something to do with it. I don't see any way to close up the gap without moving the front clip.
Old May 12, 2011 | 09:58 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
Inspect the area just under the windsheild, if you look closely, you will see where the fiberglass Firewall, is supposed to be riveted/bonded/glued to the metal Birdcage/ window/Dash frame. This is a common area problem, if you see a gap- your restoration will take much longer !
Old May 12, 2011 | 10:15 AM
Paul L's Avatar
Paul L
Why do you think that that is abnormal? Check other C3s before you make a decision. These cars were never perfect and perfections can be $$$s.
Old May 12, 2011 | 10:41 AM
Chuck72's Avatar
Chuck72
With Paul.
Position the door so as to average all the gaps. Work with what you have and get it as good as you can. Then, and only then, make your decision. After all, this junk did come off an assembly line! Look at lots of C3 pics. The left upper gap seems to be a problem area.
Chuck
Old May 12, 2011 | 10:43 AM
Chuck72's Avatar
Chuck72
Also, look into the possibility of adjusting body mounts.
Old May 12, 2011 | 11:34 AM
Roco71's Avatar
Roco71
What did it look like before you took the door off? Does the other side look the same? To me it looks as though the door needs raised a bit in the front. Is the bottom of the door even with the bottom of the fender? I recently went through this myself. I had to replace the original door with one from a donor car. I could not get it to fit I worked on it for days. I took the door off looked at it very closely only to discover that the door had been reworked and the top third had been ground down about 1/8th to 1/4th of an inch. I glassed the door edge back on and it solved the problem. It is not unheard of to close the gaps by adding some fiberglass to the doors edge or fender / surround . After you are curtain that the door is as lined up as it can be run some masking tape along the fenders edge closing the gap to what you want it to be. That would give you an idea of how much glassing it would take I bet its not as much as you think. Do a search here on the forum there are a couple of example .
Old May 12, 2011 | 11:56 AM
wan2run's Avatar
wan2run
Were the hinges/door springs new?
Old May 12, 2011 | 11:59 AM
qwank's Avatar
qwank
My '81 has a similar line on the right side.
Old May 12, 2011 | 01:03 PM
Alan 71's Avatar
Alan 71
Hi 72,
To my eye the gap makes me think the door needs to go UP a bit to even out the gap. This will affect the rear gap... what does IT look like now?
Regards,
Alan
Old May 12, 2011 | 01:27 PM
Roco71's Avatar
Roco71
I agree with Alan the front looks low. If the bolts in the door are up as far as they go you can get a little more height out of the ones in the pillar even though they are for moving the door horizontal.
Old May 12, 2011 | 02:49 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Gently jack the nose and see if the gap begins to close. If so, the clip could be loose at the door opening.
Old May 12, 2011 | 07:55 PM
81pilot's Avatar
81pilot
It is off some, but the difference in colors makes it way more noticeable now than it will be after it is painted.
Old May 15, 2011 | 06:05 PM
72 bucket of parts
Well, I have been messing with it all weekend and had come to the conclusion that the clip needed to come off. Now that I have read all the replys I think I am going to mess with it some more. I found it odd that the body line would not line up, so maybe it is a case of the door needs to go up. The top of the fender sticks out just a little farther then the door also. The difference from top to bottom is huge. it almost touches on the bottom of the door, and I can put my finger between the fender and door on the top. It is on all 4 and level. The hinges have been cleaned and re-assembled with new bushings. I tried jacking up the nose while the saddle was loose from the frame and could not close the gap at all. I think I am going to try and raise the door as suggested and see if that would look better. I really don't want to take the clip off, I'm afaid that would be way over my head. I started to head down that road and think I can set it back without any problem. The rear gap does not look bad, but if I raise the front I guess I'm not sure what the back will look like. If I can remedy the problem this way it is well worth the time to try. I really hop I don't have to take the clip off.
Kelley
Old May 15, 2011 | 06:21 PM
...Roger...'s Avatar
...Roger...
Get some pics from the side showing the entire door so we can see the gaps front and back.
Many times you just need to reposition the door to find a happy medium.
If the front clip hasn't been off I would hesitate to try and reposition it.
If it looks good everywhere else you might want to consider adding glass.
Old May 15, 2011 | 06:58 PM
Earthquake Driver's Avatar
Earthquake Driver
From: I buy all my days at the same place where the girl sells her nights
To I think I have a problem
Old May 15, 2011 | 10:08 PM
72 bucket of parts
I messed with it some more and this is where the Driver door is setting now.
I got it up a little and doesn't look real bad. I think I can make it work. I would need to add glass to the front to fix the gap, and the bottom of the back sets in a little from the quarter panel. On the curb side it looks like this.
Similar issues here. Except I can't get it high enough. The body line is lower on the door than the fender. I am thinking about making the hole on the door where the bolt slides a little longer to facilitate moving it higher. I have maxed out both the piller and door movment. the back of the passanger side door also is too far in on the bottom. I am guessing I could fill for the gap and the bottom back of both doors but am wondering why it is off this way. I know they were cheap cars, but thought the door should fit better than what I am finding.
Kelley
Old May 15, 2011 | 10:11 PM
72 bucket of parts
I see I missed one question, When I bought the car it was in boxes. I have no idea what it looked like before it was dis-assembled.
Kelley
Old May 16, 2011 | 02:14 AM
Clubby99's Avatar
Clubby99
Looks good. Glad you waited before taking your drastic planned action.
